ReadMulitpleItems via opda classic (PowerBuilder)
07 Nov 2018 11:14 - 07 Nov 2018 11:14 #6833 by support
Thanks for the update!
If, by "could not get it to work before", you mean with the old version (2018.2[corrected]), then the answer is No - it was not working from PowerBuilder with 2018.2, I have tested it as well, and it was the reason why the new methods have been added.
I am glad it works now. I do not know why the first option in the installation did not work. It might be possible to find out more about it by analyzing the log from the Setup program from that time; instructions for finding it are here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...bleshooting%20the%20Setup.html .
Last edit: 07 Nov 2018 11:14 by support.
06 Nov 2018 20:53 #6832 by scottpaxman
Ok here is some info for you..
1. The first time I installed I clicked on the first line of .net,com and excell development which I thought would work but it did not.
2. I reinstalled with only the com option on line 3 and it seems to work now.
Could this be the issue why I cound not get it to work before? I have not the oroginal methods but I was just curious if you know.
But this looks real promising to me. I just need to do some more testing.
Thanks for your great support!!!
05 Nov 2018 18:22 #6828 by support
I am using trial of the same PowerBuilder version.
What you describe looks like that the PowerBuilder is still using the old version of the QuickOPC type library. Have you exited and re-run PowerBuilder?> When installing the QuickOPC Beta, have you selected that you also want the installation for COM development, on the 2nd page of the installation wizard?
05 Nov 2018 18:08 #6827 by scottpaxman
I tried the examples but my version of Powerbuilder blows up at this line.
readItemArgumentsList.Add(readItemArguments1)
I am using Powerbuilder 2017 R03 is that what you used? I am wondering if powerbulder cannot pass the objects but the simple strings work..
I replied to your email also.
05 Nov 2018 07:40 #6822 by support
I will send you a download link for the Beta of the upcoming version, to the email address you have used to register with these forums. I would be grateful if you can give it a try, because after the release, no more API changes will be possible until the next version (several months) - only bug fixes. In principle, methods have been added to the COM interface to accept and return lists instead of arrays. For example, ReadMultipleItems becomes ReadItemList, ReadMultipleItemValues becomes ReadItemValueList etc. There will be documentation topic covering this.
Here is one of the examples/tests I have used (the whole set is already in the installation of the Beta - look under Examples-COM/PowerScript):
// This example shows how to read the values of 4 different items at once. mle_outputtext.Text = "" // Instantiate the client object OLEObject client client = CREATE OLEObject client.ConnectToNewObject("OpcLabs.EasyOpc.DataAccess.EasyDAClient") // Prepare arguments. OLEObject readItemArguments1 readItemArguments1 = CREATE OLEObject readItemArguments1.ConnectToNewObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") readItemArguments1.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" readItemArguments1.ItemDescriptor.ItemID = "Simulation.Random" OLEObject readItemArguments2 readItemArguments2 = CREATE OLEObject readItemArguments2.ConnectToNewObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") readItemArguments2.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" readItemArguments2.ItemDescriptor.ItemID = "Trends.Ramp (1 min)" OLEObject readItemArguments3 readItemArguments3 = CREATE OLEObject readItemArguments3.ConnectToNewObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") readItemArguments3.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" readItemArguments3.ItemDescriptor.ItemID = "Trends.Sine (1 min)" OLEObject readItemArguments4 readItemArguments4 = CREATE OLEObject readItemArguments4.ConnectToNewObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") readItemArguments4.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" readItemArguments4.ItemDescriptor.ItemID = "Simulation.Register_I4" OLEObject readItemArgumentsList readItemArgumentsList = CREATE OLEObject readItemArgumentsList.ConnectToNewObject("OpcLabs.BaseLib.Collections.ElasticVector") readItemArgumentsList.Add(readItemArguments1) readItemArgumentsList.Add(readItemArguments2) readItemArgumentsList.Add(readItemArguments3) readItemArgumentsList.Add(readItemArguments4) // Obtain values. OLEObject valueResultList valueResultList = client.ReadItemValueList(readItemArgumentsList) // Display results Int i FOR i = 0 TO valueResultList.Count - 1 OLEObject valueResult valueResult = valueResultList.Item[i] IF valueResult.Succeeded THEN mle_outputtext.Text = mle_outputtext.Text + "valueResult[" + String(i) + "].Value: " + String(valueResult.Value) + "~r~n" ELSE mle_outputtext.Text = mle_outputtext.Text + "valueResult[" + String(i) + "] *** Failure: " + valueResult.ErrorMessageBrief + "~r~n" END IF NEXT
Please let me know how it works for you.
01 Nov 2018 14:37 #6811 by scottpaxman
That would be GREAT thank you!!!!!
01 Nov 2018 09:33 - 01 Nov 2018 14:53 #6809 by support
I have investigated this with PowerBuilder. I tried many approaches, and none of them worked. My current conclusion is that PowerBuilder lacks the capability to properly pass COM arrays (SAFEARRAYs) to and from OLE Automation methods.
The solution I have in mind is to use a separate COM object, a kind of collection, instead of the arrays, to hold the method arguments and results. I have made an experiment and it seems to work. Unfortunately, you cannot just do it on your side - it requires that we provide new QuickOPC methods with signatures that accept and return this object, instead of the arrays.
I will try to sneak this improvement (together with some PowerScript examples showing its usage) into the upcoming QuickOPC version (2018.3), which is due in 2 weeks or less from now.
Let me know if that would be fine with you?
Bets regards
Last edit: 01 Nov 2018 14:53 by support.
The following user(s) said Thank You: scottpaxman
29 Oct 2018 17:53 #6802 by support
Thank you for the additional information. But I still do not know the reason.
I will attempt to get a PowerBuilder trial, and make my own investigation.
I will post here as soon as I have more information to the issue. I may also ask you for some guidance, or simple project showing the problem, in case I get stuck with the PowerBuilder itself.
29 Oct 2018 17:37 #6801 by scottpaxman
Error number 33
Invalid parameter type calling external object function readmultipleitemvalues at line 116 in ue_polling event of object w_plc_2_db.
This is all the data I can seem to capture..
29 Oct 2018 17:19 #6800 by scottpaxman
Thank you for your repsonse! I tried the array 0 processing idea but it did not work. let me see if I can gather some better errors codes...
Time to create page: 0.186 seconds
