Error: OPC-UA service result - Could not create a certificate via a proxy: Input file was not processes properly.
I appreciate that you have given me a global view. Here it is from my side: It is possible that the problem you have has been fixed in the version that we have in development. The changes in this area were, however, rather big, and therefore the same changes won't be ever made back to the current version. The new version (5.40) should be released in 1-2 months, but we have an Alpha of it already. If you are interested, I can send you a link to it privately. If that works, and if you can then wait for the release, fine. Otherwise, I am afraid I cannot help you more at the moment.
But let me talk global. We have a application (develope in Delphi) call IOManager. This application has a lot of addon dlls to connect to varius sources like OPCDA Server, SiemensS7 direct, snmp, and so on. Now we want connect to a OPC-UA Server on a easy way. The easiest way is a COM Server (or assemblies wrapp as COM server). Means your solution. But like it Looks, it insn't working in all Situation (like Unified Automation, UaExpert Client), or do you fix that and I can use it next week? Please give me a Statement. Do I have to look for other SDK?
For this reason, Visual Studio does not have to be installed in order to figure out the .NET Framework versions. What I need is 1) the operating system version, and 2) any installed .NET Framework version from the Control Panel (Programs). And, compare that between machines A) and
For the same reason, it is clear that EasyOpcUADemo doesn't work either on the problematic machine. This shows that there is nothing wrong with your app, it is how I suspected - something gets wrong between our component and the system or .NET Framework on machine A.
first: I can't test the .NET Version on maschine A (were the OPC Server works), because there is not Visual Studio installed. Only on Maschine B.
But if I let run your EasyOpcUADemo.exe (I think is compiled in .net) it has the same result (see attach EasyOPC-UA Demo NET.PNG and EasyOPC-UA Demo NET_2.PNG)
I'm not sure the setting of the SharedParameters are correct?
You can see what I did in WithSharedParameter.
With this Parameter it dosen't work at all.
For your understanding:
The appication Name is: IOManager.exe
The application load a DLL. Inside the DLL runs a thread with TEasyUAClient initialization.
We have other DLLs, has the same programing structure, but with OPC COM (DA).
The result of the test you can see in: WithSharedParameter.PNG
If I have to use other Parameters, please let me know.
still hoping for a solution, be online ...
Thanks for a while...
And, can you please try the following: Set certain parameters (that are otherwise determined automatically) from the code. The precise values do not matter that match. At the very of you application, instantiate the EasyUAClientConfiguration object, and set
.SharedParameters.Engine.ApplicationCertificateSubject = ...
.SharedParameters.Engine.ApplicationName = ...
.SharedParameters.Engine.ApplicationUriString = ...
.SharedParameters.Engine.ProductUriString = ...
There is a chance - not a big chance, but still a chance - that this will resolve the problem.
For more clearance: I have 2 maschine A + B. On A is the siemens OPC-UA Server running. If I let run there OPC-UA Client it fail (look on top, local). If I let run the Client on B all is OK. Attach the OK protocol from Client on B.
Note that ZIP files should be uploadable to these forums just fine. I do not know why you are renaming them to TXT.
I doubt that the problem has to do with whether the server is local or remote, because the log indicates issues that appear before any processing of the server URL even occurs. Is everything else the same? Isn't it so that you are using a different computer to run the working and non-working app?
Anyway, the issue appears to have to with the way the client certificate are being determined. We were fixing something in this area for the upcoming version, but that will not be release soon. I will check whether there is some workaround. Please expect further post here later.
if you delete the ".txt" extension of the attach "UAClient_OLab.zip.txt" from my first transmition and unzip you have the Client exe with protocol.
Here is the protocol I wrote just now on my maschine.
Please take a look of something strange in the protocol:
>> LogEntry:Information: The OPC-UA engine has determined the client certificate parameters as listed below.
SubjectName: ?FileDescription?
ApplicationName: ?FileDescription?
ApplicationUri: urn:BIE-N2132-WIN7::1.0.0.0
ProductUri: urn:literal:string:D%C3%BCrr%20EMOS.Web
