Connecting to many OPC-servers using multiple threads gives Timeouts
02 Sep 2020 09:39 #8825 by zaglerp
thank you, I tried your suggestions.
If I request all nodes using a single call it takes approx 50 seconds and some servers have a timeout.
Why do I get timeouts here? All servers are up and running.
And when requested sequentially everything is working fine...
Kind regards
Peter
02 Sep 2020 09:22 #8824 by support
I am not sure about the behaviors you have described, that would require more investigation, but none of them is the one we recommend.
The recommended approach is to call a single MultipleRead with all the target OPC servers, and let QuickOPC sort out the rest.
02 Sep 2020 07:58 #8822 by zaglerp
I try to do a MultipleRead (with 19 values) from 30 OPC-Servers running on 30 different hosts. THese servers are all up and running.
The behaviour is unclear to me:
1. Using 30 C#-Tasks running in parallel:
The whole process completes after approx. 51 seconds. At least one OPC-Server returns a timeout error (BadRequestTimeout)
2. Using 30 C#-Tasks running in sequence (using a lock):
The whole process completes after approx. 41 seconds until all Reads are completed. All OPC-server are working - no timeouts.
Can you please clarify, why
- it is faster to do this in sequence than in parallel
- some Servers have a timeout when accessed in parallel
Which procedure to you suggest for implementing this?
I have attached my test program, written in C# and using 5.58.257.1
Line 54 contains a lock that was commented out for parallel access.
Thank you for your support.
Peter
