- Thank you received: 4
XML DA: COMException(0x800401F3): Invalid class string
- goosvanbeek
Topic Author
- Offline
- Platinum Member
I'll use the eventhandler method instead.
Goos van Beek.
If you want a callback (lambda) at the same, and to specify percent deadband (which is part of GroupParameters), this leaves you with the following method only:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...angedEventHandler,Object).html
As the serverDecriptor argument, you can simply use the URL, there is an implicit conversion from string to ServerDescriptor. Similarly with itemDescriptor. And, use "new DAGroupParameters(...)" for the groupParameters argument, picking the suitable constructor overload from here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...s.DAGroupParameters~_ctor.html .
I hope this helps
- goosvanbeek
Topic Author
- Offline
- Platinum Member
See the image below for the exception message. The machine url is the OPC Labs demo server.
Exception image
Connecting to the same server without (all) the named parameters and the same url works fine.
Goos van Beek.
Note that the OPC XML servers are not addressed by machine name/serverclass, but by a single URL, so that is the most apprarent issue here
- goosvanbeek
Topic Author
- Offline
- Platinum Member
I want to use the percentDeadband parameter in a lambda expression, but this causes a comexception.
Can you help me any further?
See the code below to reproduce the exception.
Goos van Beek.
