com_exception: Description: Write not completed.
Right now I have this installed under a trial license. Let me guess that the trial allows the connection for about 30 minutes? It is consistently failing after what seems to be 30 minutes. I can confirm this is the case with the licensed version that I have.
Thanks for your help. Every project that I work on for customers I'm recommending this com object for development. It really is a great product you have here.
Your code should be handling COM exceptions from calls to QuickOPC methods (except those with "Multiple" in their name). Any error reported by the target OPC server would be a COM exception as well, and you cannot rule them out, so the code should not crash in this case.
exception 'com_exception' with message 'Error [0x800706be] The remote procedure call failed. ...
This is happening when trying to write to one opc item.
I'll keep you updated if I notice anything else.
Thanks, I'll test this one out and let you know.
-Doug
The build number is on the first page of the installation wizard.
