Exception while trying to connect to an OPC UA Server
13 Sep 2023 09:10 #12100 by support
The attachment is missing (after selecting the file, do not forget to "insert" it into the post).
We only do online forums and email, for tech support.
13 Sep 2023 08:03 #12099 by micham
See the attached document that shows all the steps in UA Expert to connect to the Honeywell OPC UA server.
I understand that supporting us with this issue is out of the scope of your support. Are you willing to remotely connect to the customer's computer (in Belgium) and help us for an additional fee?
I appreciate your answer.
    12 Sep 2023 15:04 #12097 by support
    You will have to show me the UaExpert does that. Maybe it asks the user whether he wants to trust an otherwise unaccepted certificate anyway. Or is not connecting securely (with the use of certificate) at all. There are multiple possibilities.
    To the question: "What do you recommend?" : I have already answered that. The CA certificate(s) need to be placed into the Trusted issuers store (in addition to Trusted peers). This is fairly standard procedure.
    There are also ways to tell QuickOPC to blindly accept the certificate anyway, but of course that's totally insecure.
    12 Sep 2023 14:59 #12096 by micham
    Thank you for your answer. So if something is wrong with the certificate how come that the UA Expert is able to deal with it and browsing is Okay?
    I don't know what kind of certificate is it. Our OPC Client software is installed in the customer's site in Belgium. He needs to connect to the UA Server...
    12 Sep 2023 14:54 #12095 by support
    From the name of the issuer of the server certificate ("CN=GTCHVE3SA01 Root CA."), I can guess that this is not a self-signed certificate, but a certificate issued by a certificate authority, i.e. a part of the PKI infrastructure.
    In this case also you also need to manage the CA certificates (the trusted CA certificates need to be in Trusted Issuers certificate store). This is more complicated than with self-signed certificates.
    You need to get a reasonable understanding of how this kind of security setup works, but explaining it is outside of the scope of the forum and our tech support. There are whole parts of the OPC UA specification dedicated to it. I am willing to help, but mainly with issues that have to do with specifically with QuickOPC support for this.
    12 Sep 2023 14:47 #12094 by micham
    I am getting an exception when trying to connect to an OPC UA Server (Honeywell EBI). See the details below. Browsing is Okay when using UA Expert using the same security policy and security mode.
    Exception 1)
    OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80130000) in 'static Session.Create'. OPC UA service result - {BadSecurityChecksFailed}. An error occurred verifying security.
    + Connection attempt #5; last connected at 01-01-01 00:00:00 (local); unconnected for 00:32:44.2030000.
    + The endpoint URL string used was "opc.tcp://10.19.166.10:4840".
    + The client method called (or event/callback invoked) was 'BrowseMultiple[1]'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadSecurityChecksFailed}. An error occurred verifying security.
    --> {BadSecurityChecksFailed}. Certificate chain not complete.
    SubjectName: CN=GTCHVE3SA01 OPCUA Server
    IssuerName: CN=GTCHVE3SA01 Root CA.
    Activity Trace:
    Following (3) events were gathered during the action on activity ID [26], in the order of first occurrence:
    3*Exception: {Opc.Ua.ServiceResultException} Certificate chain not complete. SubjectName: CN=GTCHVE3SA01 OPCUA Server IssuerName: CN=GTCHVE3SA01 Root CA
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.UAEngine=1
    ((26, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
    c3c0e69e-bf8f-4bfa-8e93-816783737e55: 26
    8970fe52-aaa4-40f7-9a6e-74cdcee56724: static Session.Create
    Error Code: 1
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: Opc.UA.ServiceResult=0x80130000
    Help Link:
    Internal Code: 2148728832
    Message:
    Service Result: BadSecurityChecksFailed
    Additional Info:
    Description:
    Inner Result: BadSecurityChecksFailed
    Additional Info:
    --- at Opc.Ua.CertificateValidator.GetIssuersWithChainSupportEnabled(X509Certificate2Collection certificates, List`1 issuers)
    --- at Opc.Ua.CertificateValidator.InternalValidateWithChainSupportEnabled(X509Certificate2Collection certificates)
    --- at Opc.Ua.CertificateValidator.Validate(X509Certificate2Collection chain)
    Description:
    Inner Result:
    Message:
    Qualified Symbolic ID:
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Namespace URI String:
    Standard Name:
    Status Code: BadSecurityChecksFailed
    Code Bits: 32787
    Code Bits Symbol: BadSecurityChecksFailed
    Condition: 19
    Description: An error occurred verifying security.
    Flag Bits: 0
    Has Data Value Info: False
    Info Type: NotUsed
    Internal Value: 2148728832
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Semantics Changed: False
    Severity: BadOrFailure
    Status Info: Error
    Structure Changed: False
    Text:
    Message: An error occurred verifying security.
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Standard Name:
    Code Bits: 32787
    Condition: 19
    Flag Bits: 0
    Info Type: NotUsed
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Status Info: Error
    Text:
    Service Target Site: Void Validate(System.Security.Cryptography.X509Certificates.X509Certificate2Collection)
    DeclaringType: Opc.Ua.CertificateValidator
    Module: Opc.Ua.Core.dll
    Assembly: Opc.Ua.Core, Version=1.3.342.0, Culture=neutral, PublicKeyToken=6faddca41dacb409
    CustomAttributes:
    MDStreamVersion: 131072
    MetadataToken: 1
    ModuleVersionId: de76a6af-12bb-481b-8ef7-2df5f7a00d0a
    ScopeName: Opc.Ua.Core.dll
    Source: Opc.Ua.Core
    Stack Trace:
    at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitCertificateValidator.Validate(X509Certificate2Collection chain)
    at Opc.Ua.Client.Session.Open(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain)
    at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.Create(ApplicationConfiguration configuration, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 millisecondsSessionTimeout, Func`2 identityFunction, IList`1 preferredLocales, Action`2 domainCheckError, Action`1 setupSession, Action`1 setupTransportChannel)
    at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitSession.Create(ApplicationConfiguration configuration, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 millisecondsSessionTimeout, Func`2 identityFunction, IList`1 preferredLocales, Action`2 domainCheckError, Action`1 setupTransportChannel, UAClientSessionBase clientSession)
    at OpcLabs.EasyOpc.UA.Toolkit.Client.UAClientSessionBase.<>c__DisplayClass144_0.<CreateSdkSession>b__2()
    TargetSite:
    Message:
    Source:
    Stack Trace:
    == Activity Trace ==
    TargetSite:
    Source:
    TargetSite:
    Exception 2)
    Exceptions
    Activity Trace:
    Error Code: 1
    Help Link:
    Message:
    Additional Info:
    Description:
    Additional Info:
    Description:
    Inner Result:
    Message:
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Standard Name:
    Code Bits: 32787
    Condition: 19
    Flag Bits: 0
    Info Type: NotUsed
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Status Info: Error
    Text:
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Standard Name:
    Code Bits: 32787
    Condition: 19
    Flag Bits: 0
    Info Type: NotUsed
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Status Info: Error
    Text:
    CustomAttributes:
    MetadataToken: 1
    Source: Opc.Ua.Core
    Stack Trace:
    TargetSite:
    Message:
    Source:
    Stack Trace:
    TargetSite:
    Source:
    TargetSite:
    Any idea what is causing the exception?
    Time to create page: 0.327 seconds
