How to get a list of Digital only measures?
www.quickopc.com/files/onlinedocs/QuickOpc/5.22/Reference/Qu...fe1-35f5-4eeb-72e30474db39.htm
I tried your solution, but there is one thing not working:
Here is my version:
Here is the class OpcDataTypesGenerator
public static class OpcDataTypesGenerator {
Testing this with
I habe Matrikon tools also installed and i can see that none of the Greenhouses tags/items have null as datatypes. I tried this before this refactoring (the code as you gave it) and the results are the same.
The line (in either version)
is the culprit as i think the filter is not being properly applied
You may then be able to distinguish the OPC items by their data type (such as that the digitals will probably have VarType.Bool, the analogs can have VarType.R4 or VarType.R8, etc.).
There is a related example (also in the solution with the examples, under the Console/DocExamples project): www.quickopc.com/files/onlinedocs/QuickOpc/5.22/Reference/Qu...f1e-e7d5-0da4-10834397135e.htm .
I hope this helps
i can connect to a server and get all items/tags on it, but i want only one set at a time. can i do this?
