Memory leak in QuickOPC nuget
01 Mar 2023 17:06 #11585 by support
you have a license purchased on 5/23/2022 without upgrade assurance. That means that it only covers the versions released max. 60 days after the purchase date. So, according to kb.opclabs.com/Versions , this comes to maximum version 5.63 (2022.1).
We only make bug fixes to the current version, that's why it has been made into QuickOPC 5.70 (2022.2).
Normally you would therefore need to purchase an upgrade in order to use QuickOPC 2022.2. But since you were instrumental in finding this "valuable" bug, you will get a kind of bounty, and you will receive a license key that covers version 2022.2. I will send it to you by email.
01 Mar 2023 16:03 #11584 by janko.mihelic@adnet.hr
Thanks for resolving this!
But I cannot use this new nuget because my license doesn't work with it. Was there a license break put in before fixing this memory leak? Is there any way to get a nuget without a memory leak that will work with my license?
04 Jan 2023 05:51 #11408 by support
I was able to get the event flow now. And, I was able to reproduce the memory leak.
It should be now fixed. The fix is in QuickOPC 5.70.1012.1 or later, which is on our Web site, and on nuget.org.
Please rebuild with this new version, and retest.
Thank you for reporting the issue!
03 Jan 2023 11:35 #11404 by janko.mihelic@adnet.hr
Restarted, can you try right now?
03 Jan 2023 08:47 #11403 by support
still no flow of events from the server.
02 Jan 2023 14:08 #11402 by janko.mihelic@adnet.hr
It was like that to me too, I guess it won't work for too long. Now I restarted it, and it works as before, you can try again. Comment if it's stuck again, I'll try to restart it as soon as I can.
29 Dec 2022 20:35 #11390 by support
The OPC UA server on opc.tcp://opcua.adnet.hr:81 does not give me any events, except for a single condition that remains static (in initial Refresh). This is true both in my test client code with QuickOPC, AND using UaExpert, as shown on following pictures.
If there is a different notifier node to be used, or some other trick to make it work, let me know.
23 Dec 2022 14:19 #11384 by janko.mihelic@adnet.hr
We tried the new nuget, but the constant memory consumption is still here.
I made a public test OPC-UA server so that we can have the same environment. It's a docker container from this repository:
github.com/Azure-Samples/iot-edge-opc-plc
The link is:
You will only have to accept the opc-ua server certificate (I connect with UAExpert, and copy the certificate to C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs).
It has a configuration that has two cycles, first a few minutes of a lot of events (about 5000), as fast as it can send, and then a few minutes of one event per second. The expectation is for the server to release the memory during the time it has fewer events, but that never happens. It just retains the memory. Here is a link to the gist that shows how I created the docker environment for the test opc-ua server:
gist.github.com/Janjko/7ed142f5530374ca7e45f01046d6754c
I successfully connected with it from outside of our network with the client we already sent here (just with a different link to the opc server), and I see a steady incline in memory usage. This persisted for several hours, here is a graph of around 15 min:
10 Dec 2022 12:46 #11321 by support
I was unable to reproduce the problem. Here is what I did:
1. I took your console-based program.
2. Made a special change to our currently released version (2022.2) to generate 1000 identical event notifications (instead of just 1) at the point we received them from the OPC UA stack, so that I can simulate a higher rate of notifications than what the server actually provides.
3. Changed it to reference the above special build of our currently released version.
4. Change the endpoint URL to point to my local Prosys simulation server.
5. Commented out the unused data change handler, only kept the event notification handler.
6. Ran the program and monitored the Private Bytes using PerfMon.
Memory consumption chart of cca 12 hours run:
For record, the program now looks like this:
using OpcLabs.EasyOpc.UA;
using OpcLabs.EasyOpc.UA.AddressSpace.Standard;
using OpcLabs.EasyOpc.UA.AlarmsAndConditions;
using System;
namespace OpcLabsBug
  internal class Program
  private static EasyUAClient client;
  [MTAThread]
  static void Main( string[] args )
client = [a href="www.google.com/search?q=new+msdn.microsoft.com"]new[/a] EasyUAClient();
subscribe();
Console.ReadLine();
  private static void subscribe()
UAEndpointDescriptor endpointDescriptor = [a href="www.google.com/search?q=new+msdn.microsoft.com"]new[/a] UAEndpointDescriptor( "opc.tcp://localhost:53530/OPCUA/SimulationServer" );
  if ( client == null )
client.EventNotification += Client_EventNotification;
UAAttributeFieldCollection uAAttributeFields = UABaseEventObject.AllFields;
  int eventMonitoredItem = client.SubscribeEvent(
endpointDescriptor,
UAObjectIds.Server,
  0,
uAAttributeFields );
  //private static void ProcessDataChange( object sender, EasyUADataChangeNotificationEventArgs eventArgs )
  // if ( eventArgs.Succeeded )
  // string recordId = eventArgs.Arguments.NodeDescriptor.NodeId.ExpandedText;
  // var value = eventArgs.AttributeData.Value;
  // var time = eventArgs.AttributeData.SourceTimestampLocal;
  // Console.WriteLine( $"Value change: {recordId} - {value} - {time}" );
  private static void Client_EventNotification( object sender, EasyUAEventNotificationEventArgs e )
  if (e.EventData == null)
  return;
  var Time = Convert.ToDateTime( e.EventData.FieldResults[UABaseEventObject.Operands.Time].Value ).ToLocalTime();
  var EventText = e.EventData.FieldResults[UABaseEventObject.Operands.Message].Value.ToString();
Console.WriteLine( $"Event: {EventText} - {Time}" );
I do not know what causes the difference between your and my observation, but I suggest you retest your scenario(s) with our current version (2022.), to see if that does not resolve the problem for you. There was no fix made into this version for such memory leak, but there was a large amount of other changes, and therefore it is possible that there was an "incidental" fix.
If you still get the memory leak problem with version 2022.2, then make sure you provide me with truly reproducible scenario.
09 Dec 2022 08:26 #11320 by support
Thank you for the details. I will now proceed with attempts to reproduce.
Note that I will be using the recent released version (2022.2), which is newer than you could have used. There was no specific fix for a memory leak in this version, but we do not officially support older versions, and if any code change results from the investigation, it would only be made to the newest version anyway.
Time to create page: 0.200 seconds
