Application crash in OPC code
30 May 2022 13:01 #10921 by spicerno
Thanks, version 5.63.215 is working properly
Stefano
28 May 2022 09:05 - 30 May 2022 11:14 #10919 by support
Thank you,
your information was quite helpful.
I think I was able to reproduce the issue. It could happen when there were two or more subscriptions to the same item, with different update rates (which is OK to do, and there is an optimization on our side which will internally make just one subscription with the fastest rate - and that is where the bug was).
We have made a fix. Please rebuild with version 5.63.215 or later, and retest.
Last edit: 30 May 2022 11:14 by support.
27 May 2022 16:06 #10918 by spicerno
The application creates a fresh new EasyDAClient instance, connects to the server, and performs multiple subscribeMultipleItems calls .
Then the crash occurs and process / win service is terminated.
A new process/service is started automatically some minutes later by windows, but the outcome is always the same.
27 May 2022 16:01 #10917 by spicerno
From application log we successfully connect to the OPCDA server and perform multiple subscribeMultipleItems calls to subscribe all the signals we need to acquire.
The crash occurs before any event/notification reaches our code.
No dispose, or unsubscribe, or change subscription has been performed
Stefano
27 May 2022 11:32 #10915 by support
yes, I agree - you are not doing anything wrong, this is a QuickOPC problem.
Can you specify which subscription-related methods you use in your program?
1) SubscribeItem/SubscribeMultipleItems (the answer if obviously Yes)
2) ChangeItemSubscription/ChangeMultipleItemSubscriptions?
3) UnsubscribeItem/UnsubscribeMultipleItems?
4) UnsubscribeAllItems?
In addition, do you repeatedly create (and then abandon on dispose of) EasyDAClient objects, or do you use one EasyDAClient object throughout the life of the program?
27 May 2022 11:21 #10914 by spicerno
the problem occurs in production on a customer environment.
We cannot reproduce the problem on our test environments.
However, whatever is the specific problem with this sever, the library should not drag the whole process to a crash
Is there any step I perform to provide you more diagnostic / logs from quick opc?
Stefano
27 May 2022 10:40 #10913 by support
do you have a reproducible scenario?
27 May 2022 10:02 #10912 by spicerno
The same exception occurs even with the latest version of QuickOPC
Application: NeptuneDataCollector.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentException
   at OpcLabs.EasyOpc.DataAccess.Implementation.HandleMappingEasyDAClient.GetInnerHandle(Int32)
   at OpcLabs.EasyOpc.DataAccess.Implementation.HandleMappingEasyDAClient.ChangeMultipleItemSubscriptions(OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments[])
   at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient.InnerChangeMultipleItemSubscriptions(OpcLabs.EasyOpc.DataAccess.IEasyDAClient, OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments[])
   at OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension+<>c__DisplayClass6_0`1[[System.ValueTuple`2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].<IfThenElse>b__1(System.Collections.Generic.IReadOnlyList`1<System.ValueTuple`2<System.__Canon,System.__Canon>>)
   at OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension.IfThenElse[[System.ValueTuple`2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.ValueTuple`2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Collections.Generic.IReadOnlyList`1<System.ValueTuple`2<System.__Canon,System.__Canon>>, System.Predicate`1<System.ValueTuple`2<System.__Canon,System.__Canon>>, System.Func`2<System.Collections.Generic.IReadOnlyList`1<System.ValueTuple`2<System.__Canon,System.__Canon>>,System.Collections.Generic.IEnumerable`1<System.ValueTuple`2<System.__Canon,System.__Canon>>>, System.Func`2<System.Collections.Generic.IReadOnlyList`1<System.ValueTuple`2<System.__Canon,System.__Canon>>,System.Collections.Generic.IEnumerable`1<System.ValueTuple`2<System.__Canon,System.__Canon>>>)
   at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient.DelegatedChangeMultipleItemSubscriptions(System.Collections.Generic.IReadOnlyList`1<OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments>)
   at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient.ChangeMultipleItemSubscriptions(OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments[])
   at OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.ChangeMultipleItemSubscriptions(OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments[])
   at OpcLabs.BaseLib.Collections.Generic.Extensions.IEnumerableExtension.ForAll[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Action`1<System.__Canon>)
   at OpcLabs.EasyOpc.DataAccess.Optimization.Implementation.RequestChunkingEasyDAClient.ChangeMultipleItemSubscriptions(OpcLabs.EasyOpc.DataAccess.OperationModel.DAHandleGroupArguments[])
   at OpcLabs.EasyOpc.DataAccess.Implementation.StateLockingEasyDAClient.OnLastUnlockState()
   at OpcLabs.EasyOpc.DataAccess.Implementation.StateLockingEasyDAClient.UnlockState()
   at OpcLabs.EasyOpc.DataAccess.Optimization.Implementation.SubscriptionBlendingEasyDAClient.SubscribeMultipleItems(OpcLabs.EasyOpc.DataAccess.OperationModel.EasyDAItemSubscriptionArguments[])
   at OpcLabs.EasyOpc.DataAccess.Implementation.HandleMappingEasyDAClient.MappedSubscribeMultipleItems(System.Collections.Generic.Dictionary`2<Int32,OpcLabs.EasyOpc.DataAccess.OperationModel.EasyDAItemSubscriptionArguments>)
   at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient+<>c__DisplayClass11_0.<SubscribeMultipleItems>b__1()
   at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient+<>c__DisplayClass110_0.<QueueBackEndAction>b__0()
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at OpcLabs.BaseLib.Threading.WorkItem.Execute()
   at OpcLabs.BaseLib.Threading.FifoExecution.ProcessQueuedItems(System.Object)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
Any advice ?
Stefano
26 May 2022 09:57 #10902 by support
Yes, that is the same thing.
26 May 2022 09:52 #10901 by spicerno
nuget.org reports 5.63.194 as the latest version available, published 14 days ago.
is it the same as 5.63.194.1 ? if not, where can I obtain the .1 version ?
Stefano
Time to create page: 0.089 seconds
