Accessing sessions from EasyXXClient
24 Apr 2014 14:59 #1886 by mairoldi
I'm currently using EasyUAClient and would like to know if there's a way to access the underlying session objects. What I would like to do is being able to check the session objects in order to determine if the connection succeeded or is broken for any reason (e.g. network problem, unavailable server, etc.).
While I understand that QuickOPC's architecture strives to abstract sessions away and I should only use the results from the MonitoredItemChanged event callbacks, I think access to session objects would actually allow me to have a finer control on diagnostics.
I would also like to know if the same thing can be done for classic OPC.
Thanks in advance! :)
Time to create page: 0.048 seconds
