- Thank you received: 4
- Forum
- Discussions
- QuickOPC-Classic in .NET
- Browsing, Browse Dialogs and Controls
- FSGateway OPC server browsing issue
Yes please. It's inside the InstanceParameters of EasyDAClient.
I am using this object programmatically. See below.
Dim easyDAClient = New EasyDAClient()
Should I set the EnableNativeClient to 'false' programmatically for the easyDAClient object?
Form1.DaItemDialog1.ServerDescriptor.MachineName = server_properties.server_comp_name
Form1.DaItemDialog1.ServerDescriptor.ServerClass = server_properties.RealServerName
If Form1.DaItemDialog1.ShowDialog() = DialogResult.OK Then
TagName = Form1.DaItemDialog1.NodeElement.ItemId
'Dim varType As VarType = easyDAClient.GetDataTypePropertyValue("", "OPCLabs.KitServer.2", "Simulation.Random")
Dim value As Object = Nothing
Dim exception As Exception = Nothing
Try ' Catch the exception May-29-2017
value = easyDAClient.GetDataTypePropertyValue("", server_properties.RealServerName, TagName)
Catch ex As OpcException
exception = ex
sTagType = ""
DisplayOPCException(exception)
End Try
The 'easyDAClient' variable clearly holds an instance of the EasyDAClient object, not only because the name suggests so, but because you are using it to make the GetDataTypePropertyValue call.
Thank you for your answer.
I have not used the EasyDAClient object until today.
1. Should I add it to the main form and change the EnableNativeClient to 'false'?
2. Anything else is required with this object?
3. What is the purpose of this object?
What you wrote does not change or contradict what I suggested.
The point that I was making was that the the EnableNativeClient settings should be the same across EasyDAClient objects and the dialog/control objects.
From the information I have, it looks that you have set EnableNativeClient to 'false' on the dialog object, but have *not* done that on the EasyDAClient object. Please do so.
As you can see in the code below, we have only one EasyDAClient object. It is in Form1.
What you have shown is how the EnableNativeClient is set to 'false' for the dialog object. Which is fine.
My concern was, however, about the EasyDAClient object, where the property needs to be set separately. It is highly recommended that the property is set consistently to the same value in all the EasyDAClient objects, and all QuickOPC dialog/control objects throughout the program. If it is not set like that, you end up with different parts of the program using different methods to connect to the servers.
1) The EasyDAClient is placed on the form, and the properties configured in the Visual Studio designer. See the attached screen capture.
I still have doubts about
You have not shown that part of the code. How is it done? There are multiple possibilities, such as:"EnableNativeClient is set to 'false' ."
1) The EasyDAClient is placed on the form, and the properties configured in the Visual Studio designer which then generates the code
2) you create "New EasyDAClient" and then set the property
3) It can be set from external configuration file.
Which approach are you using?
The reason I am asking is because from the error message (screenshot), it looks like that EnableNativeClient is 'true'.
- Forum
- Discussions
