- Thank you received: 0
Opc Ua ExtensionObject
More information:
- QuickOPC 2018.1 Released
- What's New in QuickOPC 2018.1
- OPC UA Complex Data Extension
- OPC UA Complex Data Reading
Next to that I will try to construct such an ExtensionObject from scratch in C# and send it. I'll keep you posted.
BR,
Carsten Voort
BR,
Carsten Voort
If so, and you then pass the extension object(s) to QuickOPC EasyUAClient.WriteXXXX method, things *may* work but we have never tested that. If you run into issues, let me know.
I assume I can also use the Opc.Ua.Core to write to the opc structures?
You may also be interested in knowing that you actually need these assemblies only during build time, and not in run time. Copies of them are inside OpcLabs.EasyOpcUA assembly and will be used during run-time automatically, if not found on disk.
What I did, on your advice, is using reflection. I figured out that I needed runtime reflection, so TypeDescriptor.GetProperties() from the System.ComponentModel. Indeed I can find the "Body" property now.
Thanks for now!
BR,
Carsten
