OPC UA Write Exception
We've found after updating to the latest builds that the OPC DA DLLs are behaving very well and are now very stable and do not lock out. We are using the same license on the same server to use the OPC UA DLLs, so we are sure it is not a licensing issue.
As I've said before, its not an exact time frame from the point of starting our windows service, but after some time, any read will response with the provided error/stack trace and we find that this never recovers. On one occasion it seemed that even a service restart didn't cause this issue to recover, though this may just be that the issue occurred immediately after the restart of the windows service. So we cannot pass blame onto the TOP Server developers as of yet.
When the type is not specified, QuickOPC first reads the type information from the server, and then attempts to convert the given value to the UA data type the server claims for (the Value attribute of) the node. Note that this is done once per session; QuickOPC then remembers the type and reuses it with further Writes to the same node, for efficiency.
When the type is specified, the above is not being performed, and QuickOPC just converts the given value to the specified type, and sends it to the server.
I am not sure how that relates to your issue, but it is good to know, as you have mentioned the difference in the behavior before/after the change.
If you have the content of the WriteRequest (and WriteResponse) messages, and you think the requests are correct (i.e. the client did what it was supposed to), why don't you contact the server vendor and ask them why the server does not behave as expected? Or do you understand something incorrectly?
We realised after posting that for some reason the WriteResponse message did not appear using the 'opcua' filter on wireshark, but it was present after all WriteRequest messages. The messages are exactly the same for both UAExpert and QuickOPC so I agree with your notion.
And, if you get the exception with "bad" status code from a QuickOPC Write, we would really be interested to see the contents of these two messages, including the WriteResponse.
Ideally, you would collect the Wireshark logs with QuickOPC, and the same with UA Expert, and possibly even the one with QuickOPC that works well - i.e. from your development environment, compress/post them here or send to us, and we would compare them and analyze.
Some of the facts, and my intuition, however, tell me that this issue is likely to be purely on the server side of things.
To the call stack that you have posted: This time you have not posted the actual exception (text + possible inner exceptions) to which it belongs. Are you sure that it is the same as you have reported originally? (the one with the StatusCode 0x80000000)
If "something" happens regularly after 30 minutes, please check if you have the QuickOPC license installed - and whether the exception is not indicating a license issue. The trial license (which kicks into effect when no other license is found) times out after 30 minutes of process run.
After a few short soak test, what we are finding is that after around 30 minutes of operation, single writes are failing and they do not recover. This is still in keeping with the boolean write that we've been discussing, but there appears to be a time element involved. The stack traces are as follows (again sorry for the poor formatting):
" at OpcLabs.EasyOpc.UA.EasyUAClient.CheckSuccess(OperationResult operationResult)\r\n at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient easyUAClient, UAWriteValueArguments writeValueArguments)\r\n at OpcService.OpcUaExtensions.WriteItem(KeyValuePair`2 refs, Boolean rethrow)"
" at OpcLabs.EasyOpc.UA.Toolkit.UAClientSession.WriteAttributes(UAWriteEntry[] writeEntryArray, Exception[]& exceptionArray, UAWriteOutcome[]& outcomeArray, List`1[]& warningsArray)\r\n at OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.InternalWriteList(UASmartSession smartSession, List`1 writeList, UAWriteResult[] writeResultArray)\r\n at OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.WriteList(EasyUASession session, List`1 writeList, UAWriteResult[] writeResultArray)\r\n at OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.Write(ICollection`1 writeListDictionary, UAWriteResult[] writeResultArray)\r\n at OpcLabs.EasyOpc.UA.Engine.EasyUAEngine.WriteAttributes(UAWriteArguments[] writeArgumentsArray, EasyUAAdaptableParameters easyUAAdaptableParameters)\r\n at OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuard[TResult](Func`1 func)\r\n at OpcLabs.EasyOpc.UA.EasyUAClient.DisposeGuardNotNull[TResult](Func`1 func)\r\n at OpcLabs.EasyOpc.UA.EasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray)\r\n at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteMultipleValues(IEasyUAClient easyUAClient, UAWriteValueArguments[] writeValueArgumentsArray)\r\n at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient easyUAClient, UAWriteValueArguments writeValueArguments)\r\n at OpcService.OpcUaExtensions.WriteItem(KeyValuePair`2 refs, Boolean rethrow)\r\n at OpcService.OpcExtensions.ProcessList(Queue`1 actions)\r\n at OpcService.Jobs.RtuHandshake.DoHandshake(Int32 rtuId, DateTimeOffset now)\r\n at OpcService.Jobs.RtuHandshake.<>c__DisplayClass1_0.<Process>b__0(Int32 rtu)\r\n at System.Threading.Tasks.Parallel.<>c__DisplayClass17_0`1.<ForWorker>b__1()\r\n at System.Threading.Tasks.Task.InnerInvokeWithArg(Task childTask)\r\n at System.Threading.Tasks.Task.<>c__DisplayClass176_0.<ExecuteSelfReplicating>b__0(Object )\r\n at System.Threading.Tasks.Task.Execute()\r\n at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)\r\n at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)\r\n at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot)\r\n at System.Threading.Tasks.Task.ExecuteEntry(Boolean bPreventDoubleExecution)\r\n at System.Threading.ThreadPoolWorkQueue.Dispatch()"
After roughly 30 minutes of operation with the same EasyUAClient any write returns with this error and continues to do so. Any ideas why this is?
So finally, you may be able to help with the OPC protocol itself then. I find that there is very little documentation regarding this.
The setup is as follows:
- Beckhoff RTU with OPC UA Server on remote static IP address
- TOP Server V5 with OPC UA driver, tags pointing at Beckoff tags, exposing own OPC UA endpoint
- Windows service writing to TOP Server over OPC UA
The system has been setup in this way as all RTUs can be viewed on a single quick client. Some of the RTUs have 3G modems and therefore we'd prefer to have a "bad" status code rather than an unreachable IP.
In any case, I've just noticed now that the boolean write from the TOP Server Quick Client to the Beckhoff RTU also caused the status code to show 'Bad' immediately after a write. I've done a wireshark trace for OPCUA.Boolean writes and only appear to capture a single "WriteRequest" packet. Should there be any additional packets?
