Could not load file or assembly
Unfortunately I do not quite understand what you wrote: "In the library I am using the NuGet package OpcLabs.QuickOpc (5.62.456). In order to use the library in my service I had to install the NuGet package (5.62.456) as well.". This seems to be a 3rd version you mentioned already. If you have installed OpcLabs.QuickOpc 5.62.456 consistently in your solution, and you are getting the error message the mentions " 'OpcLabs.EasyOpcForms, Version=5.63.232.1", then there is a version mismatch somewhere and you need to look around your solution/system to figure out where it comes from.
Regarding "I'm not sure if the exception is handled internally.": Does the exception crash your program, or are you just observing it in the debug output or breaking on it being thrown in the debugger?
- saratalley
Topic Author
- Offline
- Premium Member
- Thank you received: 0
There is some mismatch in what you provided - and it can actually be the cause of the problem.
You wrote " I tried running the examples from the QuickOPC 2020.3". But the error message lists version 5.63.232.1, which is for QuickOPC 2022.1.
I need some clarification. Here are three cases that you might be describing, and I do not know which one it is:
1. If you are really trying to use our Windows Forms-related features in .NET Core/.NET 5+ project: This is currently not supported, and it is not going to work. .NET Core projects with current QuickOPC should not reference the BaseLibForms or EasyOpcForms assemblies.
What kind of project do you have? (console app, WinForms app, WPF app, Web app, Web service, Windows service, etc.)?
2. If you are not trying to use our Windows Forms-related features : I understand that the exception is thrown, but is it unhandled? This kind of exception, if it is thrown but internally handled in QuickOPC would be OK, per design.
3. If you are not trying to use our Windows Forms-related features, and the exception is not just thrown but also unhandled in QuickOPC (i.e. you have to handle it, and/or it actually crashes your program): Only this would be a problem that we need to look at.
Please let me know.
- saratalley
Topic Author
- Offline
- Premium Member
Could not load file or assembly 'OpcLabs.EasyOpcForms, Version=5.63.232.1, Culture=neutral, PublicKeyToken=6faddca41dacb409'. The system cannot find the file specified.
I have verified that .dll exists in the bin folder. I get the error for platforms of Any CPU or x86. A colleague of mine copied my project and can run with no error. I tried running the examples from the QuickOPC 2020.3 and also get the same error.
