The CertificateGenerator utility is not installed.
It is quite possible that the current directory is not the executable directory (the code uses Environment.Directory property, which in turn uses Directory.GetCurrentDirectory() method). The Microsoft documentation and the code comments (in the .NET source) give confusing picture as to what precisely the current directory is, especially when the process starts. It certainly can change from its original value, even if it had contained the executable directory initially.
Therefore, it seems that the only "stable", reliable place where the certificate generator is to be found is the one described in Step 4.
This is not ideal; unfortunately the code that searches for the certificate generator is not ours - it is part of OPC Foundation stack & SDK. In theory we can bypass the mechanism, but doing so is more involved. I suggest to install the certificate generator into "%CommonProgramFiles%\OPC Foundation\UA\v1.0\Bin". If you install the redistributables that we have documented as needed (namely, the Local Discovery Server), that's where it will be/go anyway.
- adid@contel.co.il
Topic Author
- Offline
- Platinum Member
- Thank you received: 0
I written a windows service and in the deployment project I've made sure that the "Opc.Ua.CertificateGenerator.exe" will be placed in the service installation folder (where the service exe file resides)
and still I get an exception:
StatusCode: {BadConfigurationError} = 0x80890000 (2156462080)
Description: The CertificateGenerator utility is not installed.
If I manually copy the "Opc.Ua.CertificateGenerator.exe" to %CommonProgramFiles%\OPC Foundation\UA\v1.0\Bin then it starts to work and no error is thrown
Do you have any ideas why it happens?
Adi
Somehow, this issue was solved.
Unfortunately, can't put my finger on why, and what's changed.
Possibly, however not sure, I reinstalled with administrator privileges.
- What kind of application is your project? E.g. Windows Forms app, WPF app, Windows Service, Web app, etc.?
- What is the "Platform Target" setting of your application (project)? Is it set to "Any CPU", or "x86", or "x64"?
- Have you tried running with elevated privileges?
"Opc.Ua.CertificateGenerator.exe" file was found at "C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin".
Ya'ir.
If you are on a 64-bit system, it should be under "Program Files (x86)".
Some more information:
- The certificate generator is only need the first time the application is run.
- An administrator access with elevated privileges ("Run as administrator") may be necessary this first time.
- There is a search algorithm that looks for the utility at multiple places, and this error is thrown if it is not found at any of the locations.
The search algorithm works as follows - and stops at the moment it finds the appropriately named file:
- First it looks in the current working directory
- It looks in the "Bin" subdirectory of it.
- It proceeds to parent directory, and continues with Step 2.
- It looks in %CommonProgramFiles%\OPC Foundation\UA\v1.0\Bin
It's a new computer, and default installation choices have been made.
Thank you,
Ya'ir.
has it been working before on the same computer?
Or, is it on a new computer? If so, what installation choices have you made - anything different from the default?
- adid@contel.co.il
Topic Author
- Offline
- Platinum Member
i am trying to connect to opc server UA with opc client, and i get the UAException :
what should i do ?
thank you,
Adi Damty
