Failure -1073430509 after several easyDA.ReadMultipleItems
- Flintstone
Topic Author
- Offline
- Premium Member
- Thank you received: 0
Thank you for your prompt response.
I am using QuickOPC 5.2. I just purchased the product last week so I believe that I am using the
latest release. I believe that this problem was network related and not an issue with your product.
When the failures were happening, I was developing and testing my code from our corporate domain. The control system on which our OPC server resides is actually a subdomain of the corporate domain. Now that I moved my development PC to the actual control system domain, I am not longer experiencing these issues.
Again, thank you for your quick reply.
there can be two classes of reasons for "read not completed" error:
- The target OPC server takes very long time to complete the read operation, or is somehow blocked or hanged. This is (from or point of view) a legitimate cause for this error, the reason why it exists.
- Some kind of internal error/bug in our component. We have had reports of this in the past, but it always appeared very rarely, only to the customer, and we were not able to reproduce it. It looks like than a background thread that handles the operations in our component may be blocked or terminated, causing the error.
In fact we are currently setting up a stress test system where we aim to trigger such rare failures if they exist - and then fix it. But that will take longer - not be a matter of days.
In your case, I am quite surprised that it is so "easy" to invoke this problem. Either it is truly cause by the target OPC server in this case, or you have (by accident) managed to find the "right" way to cause it.
Would it behave the same if you changed the target OPC server to something else - e.g. our simulation server?
I would be happy to work with you, if you agree, to get the structure of your program over from you, and try to reproduce the problem here. I will be, however, on travel until Wednesday, so can only pick it up then.
Which version and build are you using please?
- Flintstone
Topic Author
- Offline
- Premium Member
Class1 - works
Class2 - works
Class3 - may or may not work - may have some failures and some successes or all failures
Class4 - may or may not work - may have some failures and some successes or all failures
Class5 - may or may not work - may have some failures and some successes or all failures
Class6 - may or may not work - may have some failures and some successes or all failures
or if I call them in this order
Class5 - works
Class6 - works
Class1 - may or may not work - may have some failures and some successes or all failures
Class2 - may or may not work - may have some failures and some successes or all failures
Class3 - works
Class4 - works
Is there something that I am not doing correctly? Thank you for any guidance you can give.
// C# code
namespace WpfHost
class ExtruderExam
public DAVtqResult[] AllExtruders;
public ExtruderExam ()
AllExtruders = checkExtruders();
private DAVtqResult[] checkExtruders()
// Create the OPC Client object
EasyDAClient easyDAClient = new EasyDAClient();
// Create an OPC Server object
OpcLabs.EasyOpc.ServerDescriptor opcServer = new OpcLabs.EasyOpc.ServerDescriptor("04PRDP1S", "OPCServer.WinCC.1");
// Create all the items to read
DAItemDescriptor[] allItems = new DAItemDescriptor[4];
allItems[0] = new DAItemDescriptor("L1_OVERVIEW/L1_EXTRUDERS/L1_EXTRUDER1/DRV_EX1/MTR.Fwd#Value");
allItems[1] = new DAItemDescriptor("L1_OVERVIEW/L1_EXTRUDERS/L1_EXTRUDER2/DRV_EX2/MTR.Fwd#Value");
allItems[2] = new DAItemDescriptor("L1_OVERVIEW/L1_EXTRUDERS/L1_EXTRUDER3/DRV_EX3/MTR.Fwd#Value");
allItems[3] = new DAItemDescriptor("L1_OVERVIEW/L1_EXTRUDERS/L1_EXTRUDER4/DRV_EX4/MTR.Fwd#Value");
// Declare the object that will hold all the info for the tags being read
DAVtqResult[] allTags = easyDAClient.ReadMultipleItems(opcServer, allItems);
return allTags;
private List<string> _CurrentExtruderValues = new List<string>();
private string _ExtruderValues = "";
DAVtqResult[] AllExtruders = new ExtruderExam().AllExtruders;
for (int i = 0; i < AllExtruders.Length; i++)
_ExtruderValues += (AllExtruders.Vtq.Value).ToString() + ";";
_CurrentExtruderValues.Add(_ExtruderValues);
