If you are developing in .NET, but are using the OPC-UA (OPC Unified Architecture), please post in the QuickOPC-UA category instead.
about : BadSessionIdInvalid
30 Apr 2025 06:42 #14025 by support
Replied by support on topic about : BadSessionIdInvalid
QuickOPC maintains the connections automatically. If you are not subscribed but just doing reads/writes/method calls form time to time, repeated connect/disconnects are normal. They should not cause any problem, but if you do not like them see User's Guide for "connection control" topics.
Thread count can fluctuate and unless the number of threads continues to rise ad infinitum, there is no issue either.
Invalid session Id can appear, among other reasons, during disconnect process. It is qualified as a warning because unless there is a real problem, it can be ignored.
28 Apr 2025 02:55 #13925 by xpycy001
I didn't see any specific errors in the code itself. From the trace logs, I can see the process of constantly trying to reconnect and disconnect, while the number of threads slowly increases
16 Apr 2025 08:57 #13550 by support
Do you actually get any error/problem in your app? If so, please describe which method or event throws the exception or returns it, and include full text of the exception message, and if there is an .InnerException, then the same for the inner exception, recursively.
Or, are you just investigating the meaning/cause of the log entries - but without seeing a particular error in the code itself?
15 Apr 2025 10:43 #13549 by xpycy001
Dear  Support:
In my client.exe , found reconnect error : BadSessionIdInvalid ,EasyUaClient base setting :
1 EasyUAClient.SharedParameters.EngineParameters.ReconnectionPeriod =300 *1000 ( 300seconds )
2 EasyUAClient.AdaptableParameters.SessionParameters.ServerShutdownRetrialDelay =300 *1000 ( 300seconds )
3 EasyUAClient.AdaptableParameters.SessionParameters.SessionConnectTimeout = 60*1000  (60 seconds)
EasyUAClientOnLogEntry-Trace .log  content :
01:02:16.957,EvId:4051,Warning The OPC-UA client session with connect sequence number 1937 on endpoint URL "opc.tcp://10.31.199.228:4840" has encountered a publish error with code 0x80250000 for subscription ID 0 and sequence number 0. The error might be from the Publish or the Republish service. Further publish errors with this code on this session will not be logged.
   Service result: BadSessionIdInvalid 'BadSessionIdInvalid'.
other same log at : 01:07:16.955,EvId:4051 .....Service result: BadSessionIdInvalid 'BadSessionIdInvalid'.
01:12:16.954 ,EvId:4051 .....Service result: BadSessionIdInvalid 'BadSessionIdInvalid'.
01:17:16.958,EvId:4051 .....Service result: BadSessionIdInvalid 'BadSessionIdInvalid'.
01:22:16.965,EvId:4051 .....Service result: BadSessionIdInvalid 'BadSessionIdInvalid'.
look forward to your reply
Simon
2025.04.15 18:43
