OLE error code 0
You understand that now you need to test .Succeeded or .Exception of the returned result element(s), and also the status in the attribute data, before accessing the actual value, right?
It would be great if, after you finalize your work, you let me know here whether the original issue (pop-up boxes with OLE error code 0) has been resolved.
- info@software2000.it
Topic Author
- Offline
- Platinum Member
- Thank you received: 2
To work around it, try using ReadValueList instead of ReadMultipleValues. The example (in PowerScript) of that is below:
Basically, you create the same UAReadArguments as you already have, but then, instead of placing them into a VFP array, you create an "OpcLabs.BaseLib.Collections.ElasticVector", and use its Add method to add the arguments to it. And then pass the elastic vector to the ReadValueList method. The result is a list that can, however, be indexed as an array (if you get pass the ReadValueList method and get issues extracting the result elements, let me know here, too).
Topic Author
- Offline
- Platinum Member
this is the code snippet and attached screenshot of the error.
I don't know what to do anymore, help ...
THANKS
You will need to take an example in some other COM-based language, such as VBScript or Delphi (Object Pascal), and rewrite them in FoxPro. These examples are here:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0multiple%20item%20values.html
Topic Author
- Offline
- Platinum Member
below is a small piece of code where I invoke the ReadValue several times to test if there are alarms.
Can you please piostarmi a VisualFoxpro snippet to use the ReadMultipleValue method instead of ReadValue and maybe how to use events to receive an event if an alarm occurs?
I would be very grateful I can't find anything on the net
the code you posted does not show the error handling, which is what I wanted to look at.
There is no way to "pre-check", and there should be no reason for it, because when mechanisms for handling errors work well, one can simply check the result of the operation, without having to pre-check something.
If, for some reason, the error from ReadValue method cannot be "caught", I suggest to use some of the methods that do not throw errors for operation failures; instead, they return objects that you can further inspect to test whether the operation succeeded or failed. That is, you can use ReadMultipleValues or ReadValueList instead. If you read just one node, you will construct an argument array or list with one element, and an array with one result element will be returned to you.. The code will be longer, but the advantage is that these method never "throw" an error. Instead, your code will look at the Exception property of the result element, and if it is null, there was a success. If it is not null, there was a failure, and the Exception property contains an exception object with the details.
Topic Author
- Offline
- Platinum Member
oClient = CREATEOBJECT("OpcLabs.EasyOpc.UA.EasyUAClient")
oClient.ReadValue(alltrim(.w_URI), "nsu=urn:eclipse:milo:hello-world;ns=2;s="+alltrim(.w_NODOM)+"/"+alltrim(&MNEMONIC))
when the machine is turned on no problem, when it is turned off everything goes haywire, the softweare no longer responds, is there no way to check if the machine is turned on by some command before reading or writing?
thanks
this might be some error in OEL Automation "plumbing" inside Visual FoxPro. We do not raise "OLE error code 0" form our code.
Which QuickOPC method is causing this precisely? Such as Read, ReadMultiple, ReadValue, ReadMultipleVaklues, etc.?
Can you post here the snippets of your code that show how you call the method, and how you do the error handling?
Topic Author
- Offline
- Platinum Member
We have a problem urgently enough to solve, I have already checked on the forum but I have not found anything that can help me.
We use the COM part of your application through VisualFoxPro and, if the ocpua server and the related connected machinery are turned on, everything works correctly; on the contrary, if the server is off, obviously an OLE error is returned which I can avoid by testing before communicating if the server's IP address responds.
If, however, the machine are spent after the default easyOPC timeout I receive an OLE error as per attachment and despite having instanced the ON ERROR function of visulafoxpro the OCX error is constantly presented to me.
What can we do?
