Memory Leak in Alarm&Event
19 May 2014 12:38 #1979 by Filliolej
Any news?
19 May 2014 07:57 #1977 by Filliolej
18 May 2014 13:26 #1974 by support
Replied by support on topic Memory Leak in Alarm&Event
No (because you are after the maintenance period). But because you have discovered this problem, we will provide you with a complimentary commercial license for version 5.23, free of charge.
Should be in your email either today or tomorrow.
16 May 2014 17:51 #1970 by Filliolej
OK thanks, i will download the 5.23.1196.1 version. Does my licence (for 5.12) work with 5.23?
16 May 2014 13:38 #1968 by support
Hello, please download and test QuickOPC 5.23.1196.1, which is the current build of version 5.23 in the Download area of this site.
The memory leak should be fixed. Screenshots from the testing are attached.
13 May 2014 08:13 - 13 May 2014 10:57 #1963 by Filliolej
perfect, thanks.
We are waiting B)
Last edit: 13 May 2014 10:57 by Filliolej.
13 May 2014 06:44 #1961 by support
Hello, we have found and fixed a leak, but further testing revealed that a residual (smaller) leak still exists. We continue working on it.
08 May 2014 08:53 #1950 by Filliolej
OK, I hope you fix the problem very soon because our client needs :)
08 May 2014 07:25 #1948 by support
Thank you - I have reproduced the problem (with version 5.23.1162.1). We will work on fixing it. Please allow several days before I post an update on this.
The following user(s) said Thank You: Filliolej
07 May 2014 15:53 #1942 by Filliolej
20 events (in the same time) every 3seconds (I tried also every 10sec and it is the same).
Time to create page: 0.166 seconds
