OPC Servers disappeared after installation of QuickOPC
10 Apr 2015 14:29 #3046 by support
I am glad it is solved. We do not manipulate OPCEnum security settings ourselves. But the QuickOPC setup program calls an installation of OPC Core Components from OPC Foundation, therefore my guess is that something went wrong there - we cannot influence that, though.
10 Apr 2015 13:27 - 10 Apr 2015 13:42 #3044 by MSiatrak
1. Can you please restart the machine to see if it helps.
Yes - didn't help
2. Do you see OPCEnum in the list of running processes in the Task Manager?
YEs it is
3. Do you see OPCEnum in the list of Services? If so, does it shows with status being Running?
Yes - it is running and in Autostart
4. Do you see "OPC Code Components Redistributable" in the list of programs in Control Panel? If so, which version does it indicate?
Yes - OPC Core Components Redistributable 105.0 x64 and 105.1 x86
5. Have you been able to see the OPC servers on that computer through OPC Explorer before installing QuickOPC?
Yes
6. How have you installed QuickOPC? Using its installation program, or by deploying its parts manually?
Installation program - Custom installation with Build .Net preset
7. Is it a 32-bit or 64-bit operating system?
x64
Matrikon OPC Expert shows OPC error 0x80040153
--SOLVED
Adding Anonymous logon for OPCEnum helped! OPC servers are visible again.
Last edit: 10 Apr 2015 13:42 by MSiatrak. Reason: Adding more information
10 Apr 2015 13:09 #3043 by support
Most OPC clients discover the OPC servers by means of the OPCEnum service. QuickOPC uses it as well, but when it fails, it falls back to registry (or Remote Registry) browsing. The hypothesis is that the OPCEnum is not working.
10 Apr 2015 12:52 #3042 by MSiatrak
I have a strange problem after installing OPC labs on a target machine.
With use of any OPC Explorer I am not able to see any OPC servers installed on my machine. There are already installed 5 OPC servers, but after installation of OPCLabs they are not visible for only opc explorer software.
Application written with the use of OPCLabs library is working properly, but I am not able to use any OPC Client other that OPCLabs apps client!
I've installed QuickOPC-5.33.
The fast response will be appreciated!
