- Thank you received: 0
Nuget Package
I suggested to Google for "collect nuget packages locally for offline use", or similar, already. For starters, each package has list of dependencies in its .nuspec file.
Using assembly references instead of package references is not supported. I suggest that you do not even try.
If you want a dev machine that is not connected to Internet, you can still do it with NuGet packages. You just need to collect them, store locally, and configure a NuGet package source(s) that are on the local disk.
If you are using the Setup program of QuickOPC, our NuGet packages are already present on your disk in a directory (NuGetPackages) under where the product is installed. So you just need to add a NuGet Package Source (e.g. in Visual Studio) pointing to that directory. However, the transitively referenced packages that our packages depend on will not be on the disk by default, so you need them as well. Try Google for "collect nuget packages locally for offline use" or so.
- Brian.Shafer@nucor.com
Topic Author
- Offline
- Senior Member
