Form crashes when open de .cs of the form in VS
20 Apr 2018 20:13 #6253 by support
Unfortunately I was not able to reproduce the problem. I took a virtual machine with fresh install of Windows, installed the precise version/build of the Visual Studio, and QuickOPC 2017.1 as you stated.
I can open the solution, and frmQuickClick.cs in the designer, without problem. It can be seen (together with VS About box, indicating its version) on the screenshot below.
I would like to help you but without being able to reproduce th eissue, it is nearly impossible.
Are you getting any specific error message when it crashes?
17 Apr 2018 06:27 #6235 by support
I ask for a little patience, we will try to reproduce and let you know here.
12 Apr 2018 21:45 #6230 by IsmaelGalaviz1995
Visual Studio version : Enterprise 2015 v.14.0.25431.01 Update 3
QuickOPC version : 2017.1
So, the solution crashes when opening the .cs with OPC UA using it.
05 Jan 2018 08:23 #5811 by support
Hello, can you please:
1. Zip your project and post it here.
2. Indicate the version of Visual Studio used.
3. Indicate the version/build of QUickOPC used.
I will then try to reproduce it.
04 Jan 2018 17:16 #5808 by IsmaelGalaviz1995
I have tried this with in an empty project/solution to be sure if there is no conflict with my original project, so I built a new solution and added the EasyDAClient, so, the component is added without any problem, BUT, when I open the .cs, Visual Studio crashes, and this only happens when the EasyDAClient component is added.
Any suggestions or solution ???
Kind regards
Ismael
