Wait between connection and actual subscription
22 Apr 2016 07:27 #4010 by support
Dear Sir,
unfortunately there is no such feature built into the product; but there are workarounds.
(BTW, I am sure you realize that if the OPC server indeed behaves as described, it is a bug in the server that should be primarily handled in there).
You can try to subscribe first with just one item, wait for some time, and then proceed with your other (many( subscriptions. The first item does not even have to be a valid one; in fact, choosing an invalid one (e.g. unknown Item ID) would probably be better, because it should be rejected right away and won't consume anything on the server side later.
It is also possible to achieve a similar effect by a dummy one-time operation, such as Read or Browse. In this case, however, care should be taken so that the wait delay is shorter than the (configurable) Hold period of the client, otherwise the connection might be closed before the "real" subscription occurs (which would then cause a re-connection, defeating the purpose).
21 Apr 2016 09:09 #4006 by filip.slachmuylders@pa-ats.com
Dear support
Is there a way to have a delay between the connection to the OPC server and the actual start of subscribing values for reading?
Dim WithEvents oEasyDAclient As New OpcLabs.EasyOpc.DataAccess.EasyDAClient
Dim aoReadarray() As OpcLabs.EasyOpc.DataAccess.OperationModel.EasyDAItemSubscriptionArguments
oEasyDAclient.SubscribeMultipleItems(aoReadarray)
The reason is that the OPC server seems to hang, when requesting many values, this migh be cause by the fact that the OPC server does not have time to keep up and gets confused resulting in a hanged state
Thanks in advance
Filip
Time to create page: 0.200 seconds
