Client disconnection
26 Jan 2011 12:45 #235 by naork
Replied by naork on topic Re: Client disconnection
This solved my problem. It's working ok now.
Thank you very much!
26 Jan 2011 10:21 #234 by support
Replied by support on topic Re: Client disconnection
there is a logic inside the component that optimizes the use of servers, and it holds the client connection from the component to the target OPC server longer than the application code requires. This is by design, and helps in situations where the application code may be creating and disposing the objects frequently; if this is passed to the target OPC server, the performance would suffer terribly.
By default, the component holds the connection to the server for 2 minutes, so I assume you simply haven't waited that long to see it happening. You can influence this behavior by manipulating HoldPeriods.TopicRead and .TopicWrite properties of the EasyDAClient. You can set them to lower values or even zero, at the expense on losing some of the optimization described above.
More such settings exist - see e.g. www.opclabs.com/onlinedocs/Qui ....
I hope this helps
26 Jan 2011 10:03 #233 by naork
Client disconnection was created by naork
I'm having a problem with EasyDAClient. I need to connect to an OPC server, read/write some items and then disconnect from it. It all works fine, but after I call Dispose() on the client, the server deletes all items and groups held by the client, but does not disconnect the client itself. The client disconnection happens only after I close my application.
It seems like the Dispose() method is not releasing all the resources and the client stays connected, even when the EasyDAClient object is not in use anymore.
Is this a known behavior? Is there a way to achieve what I want?
