KEPServer Data Scan Time
01 Nov 2017 08:31 #5624 by support
Replied by support on topic KEPServer Data Scan Time
Are you using QuickOPC? This forum is for users of our client toolkit.
Also, is the answer you received here: opcfoundation.org/forum/classic-opc-da-ae-hda-xml-da-etc/kepserver-data-scan-time/#p897
satisfactory?
23 Oct 2017 18:35 #5611 by Pat
KEPServer Data Scan Time was created by Pat
Has anyone run into a problem with setting the scan time for items in KEPServer? I have a PLC sending data to the server, and through RSLogix I can see that values are coming from the device every 30 or so milliseconds, but KEPServer is only able to refresh the values coming in every ~2.5 seconds. I’ve changed the Item Update Interval and Update Rate to 10 ms in every setting section I could find within KEPServer, but nothing changes how often it refreshes its data. Any advice? I’m running KEPServerEx 6.2.
