Server Auto Tag Creation Doesn't Work with QuickOPC
04 Mar 2018 08:37 #6101 by support
Yes, this is the right way
03 Mar 2018 23:57 #6100 by jgyenese
It is our own OPC server for our SCADA application. It is built using SlikDA5 and is very simple - it is used primarily for inter-application sharing of data, not for reading from any field devices. That's why we wanted to add tags dynamically.
I was able to get it working after reviewing your code. The only problem was I am using VB6 which doesn't support initializers, so I had to set the value directly. However, I could not set the requested data type this way:
Dim arg as DAItemValueArguments arg.ItemDescriptor.RequestedDataType = VarTypes.VarTypes_R8
I had to go down an another step like this:
Dim arg as DAItemValueArguments arg.ItemDescriptor.RequestedDataType.InternalValue = VarTypes.VarTypes_R8
It does work. Is this the proper way to do this?
02 Mar 2018 13:00 #6098 by support
this should be possible.
For single item write:
// This example shows how to write a value into a single item, specifying its requested data type. using OpcLabs.BaseLib.ComInterop; using OpcLabs.EasyOpc.DataAccess; namespace DocExamples { namespace _EasyDAClient { partial class WriteItemValue { public static void RequestedDataType() { var client = new EasyDAClient(); client.WriteItemValue("", "OPCLabs.KitServer.2", "Simulation.Register_I4", 12345, VarTypes.I4); // <-- the requested data type } } } }
For multiple-items write:
// Shows how to write into multiple OPC items using a single method call, specifying their requested data types. using System; using System.Diagnostics; using OpcLabs.BaseLib.ComInterop; using OpcLabs.BaseLib.OperationModel; using OpcLabs.EasyOpc.DataAccess; using OpcLabs.EasyOpc.DataAccess.OperationModel; namespace DocExamples { namespace _EasyDAClient { partial class WriteMultipleItemValues { public static void RequestedDataType() { var client = new EasyDAClient(); Console.WriteLine("Writing multiple item values..."); OperationResult[] resultArray = client.WriteMultipleItemValues(new[] { new DAItemValueArguments("", "OPCLabs.KitServer.2", "Simulation.Register_I2", 12345) { ItemDescriptor = { RequestedDataType = VarTypes.I2}}, // <-- the requested data type new DAItemValueArguments("", "OPCLabs.KitServer.2", "Simulation.Register_R4", 234.56) { ItemDescriptor = { RequestedDataType = VarTypes.R4}} // <-- the requested data type }); for (int i = 0; i < resultArray.Length; i++) { Debug.Assert(resultArray[i] != null); if (resultArray[i].Succeeded) Console.WriteLine("Result {0}: success", i); else { Debug.Assert(resultArray[i].Exception != null); Console.WriteLine("Result {0}: {1}", i, resultArray[i].Exception.GetBaseException().Message); } } Console.WriteLine("Reading multiple item values..."); ValueResult[] valueResultArray = client.ReadMultipleItemValues("OPCLabs.KitServer.2", new DAItemDescriptor[] { "Simulation.Register_I2", "Simulation.Register_R4" }); for (int i = 0; i < valueResultArray.Length; i++) { Debug.Assert(valueResultArray[i] != null); Console.WriteLine("valueResultArray[{0}]: {1}", i, valueResultArray[i]); } } } } }
Which OPC server are you using please?
01 Mar 2018 23:56 #6095 by jgyenese
I have an OPC server that will automatically create new tags if the client requests it in one of two ways:
1. By calling the server Tag Validation method.
2. By calling the server Add Tag method.
I send an array of values to the server using DAClient.WriteMultipleItemValues. According to the server logs, QuickOPC is indeed calling the Add Tag method, but it doesn't include a requested Data Type. The server then creates a tag using a default type which is a long integer. But I need to send more than just integers.
Is there some way I can tell QuickOPC to send Data Type information to the server? Or can I make some other call to accomplish this goal?
Time to create page: 0.162 seconds
