How to set DataSource and value age
11 Dec 2014 16:49 #2568 by pgilbert
Replied by pgilbert on topic How to Decode the DAVtq ?
Many thanks this answer my question.
11 Dec 2014 08:34 #2566 by support
Replied by support on topic How to Decode the DAVtq ?
The values are as follows:
/// <summary>Selects the data source for OPC reads (from device, from OPC cache, or dynamically determined).</summary> [v1_enum] typedef enum { /// <summary>The data source (memory, OPC cache or OPC device) selection will be based on the desired value age and /// current status of data received from the server.</summary> ByValueAge = 0, // OCK_DS_BY_VALUE_AGE /// <summary>OPC reads will be fulfilled from the cache in the OPC server. </summary> Cache = 1, // OPC_DS_CACHE /// <summary>OPC reads will be fulfilled from the device by the OPC server. </summary> Device = 2, // OPC_DS_DEVICE } DADataSource;
Note: Using an OleView utility from Microsoft SDK's (or included with Visual Studio), one can view the contents of the type libraries that go with the product - useful when the consuming tool does not allow the access to enumeration values from the type library natively. I understand, however, that with some tools (like yours) this is not something you would normally do anyway. Keep asking if you need more...
The following user(s) said Thank You: pgilbert
10 Dec 2014 20:36 #2565 by pgilbert
I would like to set programmatically in Client Mode the Data source by value age. In our program we have access to this property by doing: ⎕WI 'xClientMode.DataSource'. This property seems to accept only an integer. What would be the integer value for: 'By value age' 'OPC cache' 'OPC device'.
To set the DesiredValueAge to 5 sec. we just do: ⎕WI 'xClientMode.DesiredValueAge' 5000
Thanks in advance,
