WriteValue works where WriteMultiple does not
27 Mar 2014 16:50 #1789 by support
I am glad you made it work - even before I could reply.
FYI, the "Write" methods are all implemented on top of "WriteMultiple", and the "WriteValue" methods are all implemented on top of "WriteMultipleValues" methods. So, if e.g. "WriteMultiple" works, and "Write" does not, the difference must be somehow related to the arguments being passed in.
In OPC-UA, the spec is more strict about the type of value that goes to the Write service of the OPC-UA server, compared to OPC Data Access. As you can see (and the doc describes), it can get problematic at times. Basically, you either have to properly specify the type with each value written (or have the value already in the precise type), OR we (on the client side) will allow you to omit the type, at the cost of performance.
27 Mar 2014 13:00 #1788 by cdunlap
I have gone back to using the WriteMultiple function, but not including the Typecode in the parameters. This seems to work just as well as the WriteMultipleValues function.
As I was reading the Concepts document, I discovered that, if a TypeCode is not supplied, WriteMultiple will actually do a read of the item to determine the type. I was doing this with my code and the setting the TypeCode to the return item type.
It seems to be working fine at the moment.
27 Mar 2014 12:41 #1787 by cdunlap
I apologize for not giving the exception earlier. It gives a BadTypeMismatch ({*** Failure -2139881472 (0x80740000): OPC-UA service result - An error specific to OPC-UA service occurred.}) which is even more strange since I get the type from it before trying to write.
When using the WriteValue, where I don't specify the type, it will write.
I am using TOP Server 5.9.170.0 - I checked the release notes for anything particular to that driver, but I didn't see anything about a bug with
Thank you again.
27 Mar 2014 06:06 #1786 by support
can you please give following more detail:
  • What is the version of the TOP Server (the full, precise version number).
  • Do you get any error, and if so, what error precisely, when you say that it does not work? Note that you need to check the output of the WriteMultiple one by one, it does not throw exceptions for this.
26 Mar 2014 21:16 - 27 Mar 2014 06:01 #1785 by cdunlap
I have been using WriteMultiple to write to different PLCs and it works for all except one special case, a SLC 500 and an integer tag. I have included my code that works for all of the other scenarios.
Here is my WriteMultiple function and how I call it….
Calling routine:
DimsServerName As String DimsTagRead(0) As String DimsTagWrite(0) As String DimoWriteValues(0) As Object DimoTypeCode(0) As TypeCode DimbResult As Boolean= False bResult = OPC_UA_WriteMultipleItems(“192.168.2.115:49380”, “SLC500.SLC500.N7:0”, "nsu=TOP Server;ns=2;s=", “123”, oTypeCode)
End of calling routine
FunctionOPC_UA_WriteMultipleItems(ByValsServerName As String, _ ByValTags() As String, _ ByValsServerType As String, _ ByValoValues() As Object, _ ByValoTypeCode() As TypeCode) As Boolean DimReadValues() As ValueResult= Nothing 'Read tags to get varibale types OPC_UA_ReadMultipleItems(sServerName, Tags, sServerType, ReadValues) DimI As Integer DimeasyUAClient1 = New EasyUAClient() 'create an array to store the results of the write instruction DimResults() AsOpcLabs.BaseLib.OperationResult 'OpcLabs.EasyOpc.UA.UAWriteResult DimArgs(UBound(Tags)) As UAWriteArguments Try 'iterate through the array and add tags and values to Argument object ForI = LBound(Tags) ToUBound(Tags) oTypeCode(I) = System.Type.GetTypeCode(ReadValues(I).Value.GetType()) Args(I) = NewOpcLabs.EasyOpc.UA.UAWriteArguments("opc.tcp://"& sServerName, _ sServerType & Tags(I), _ NewOpcLabs.EasyOpc.UA.UAAttributeData(oValues(I)), oTypeCode(I)) Next IfIsNothing(Args) = False Then 'Write the items Results = easyUAClient1.WriteMultiple(Args) End If Catchex As Exception 'display an exception to screen MessageBox.Show(ex.Message) Finally ForI = LBound(Tags) ToUBound(Tags) IfResults(I).Succeeded = False Then OPC_UA_WriteMultipleItems = False 'Bad Write Exit For Else OPC_UA_WriteMultipleItems = True 'Good Write End If Next 'Kill objects easyUAClient1.Dispose() IfIsNothing(easyUAClient1) = False TheneasyUAClient1 = Nothing IfIsNothing(Results) = False ThenResults = Nothing IfIsNothing(Args) = False ThenArgs = Nothing End Try End Function
If I switch to WriteValue and try to write to the int tag in the SLC 500, it will work.
I am using TOP Server, Allen-Bradley Ethernet driver, and OPC.Net UA 5.3. I have also had success using a different OPC server and WriteMultiple.
More observations I have:
When using an SLC 500, I cannot write to PLC address unless the Tag NAME is defined in TOP Server. The Tag NAME must match the PLC address. For example: SLC500.SLC500.N7:0
Defining tag name N7:0 and address N7:0 reads and writes properly to N7:0
Defining tag name SSN7:0 and address N7:0 reads properly from N7:0 but cannot write to N7:0
Removing from TOP Server tag name N7:0 and address N7:0 reads properly from N7:0 but cannot write to N7:0
Other tags, such as Strings (ST28:0) or Booleans (B3/0) seem to work OK either way.
Any ideas if this would be related to something weird in the server driver or if it something weird with WriteMultiple.
Last edit: 27 Mar 2014 06:01 by support. Reason: used [code] for better formatting
