Connecting to remote Machines via CODE
14 Aug 2013 19:25 #1387 by arahming
I did some further analysis and this is what I found
Matrikon OPC Client can read the data from the OPC server
OPC Foundation sample client can read the tags and can create a subscription
if OPCDA.net is install on the same server is AXS4 than everything works. I have verified DCOM and my local security policy are correct
it seems that when I try to access a remote machine using anything from OPCLabs it does not work if anyone has worked with SISCO AXS4 in a remote computer scenario any help is appreciated
14 Aug 2013 16:04 #1384 by support
Can you please send the inner exception as well.
What type of project is it (e.g. desktop app - WinForms, Windows service, Web service, or...?)
13 Aug 2013 15:38 - 06 Mar 2015 07:20 #1381 by arahming
I am trying to use some simple code I copied from Softwaretoolbox.com to connect to a remote OPC server and check a tag. I have installed the same server on my local computer and it works on the but will not connect to any remote machines I have put the server on. I have tested the remote OPC servers with other OPC clients from the machine I am running this code on and they connect fine here is the code
try { //create the OPC Client object OpcLabs.EasyOpc.DataAccess.EasyDAClient easyDAClient1 = new OpcLabs.EasyOpc.DataAccess.EasyDAClient(); //declare the object that will hold all the info for the tag being read OpcLabs.EasyOpc.DataAccess.DAVtq tag = new OpcLabs.EasyOpc.DataAccess.DAVtq(); //read the tag tag = easyDAClient1.ReadItem("SISCO2", "SISCO.AXS4ICCP.3", "IBDR1:LocalStatus~NumCfgLinks"); //System.Text.RegularExpressions.Regex.Replace(watchServer, @"[^\w\.@-],", ""), System.Text.RegularExpressions.Regex.Replace(watchtag, @"[^\w\.@-],", "")); //check that we have a value if (tag.Value != null) { //display the value, quality as a string and timestamp MessageBox.Show(string.Format("Value: {0}, Quality: {1}, Timestamp: {2}", tag.Value.ToString(), tag.Quality.QualityChoiceBitField.ToString(), tag.Timestamp.ToString())); } } catch (Exception ex) { MessageBox.Show("Error: " + ex.Message.ToString()); } }
the error is attached
Last edit: 06 Mar 2015 07:20 by support. Reason: code formatting
