- Thank you received: 0
OPC UA - User Name with backslash (\\)
Thank you for your support. I works directly with: Dim endpoint As UAEndpointDescriptor = New UAEndpointDescriptor(OPCServer).WithUserNameIdentity(UserName, Password)
one such example is here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...nregister%20all%20clients.html
And you can put a backslash into the user name and will stay there. Just do not try to get it back from UAEndpointDescriptor.UserName, because that is a different thing.
If you really want to check that the the backslash "stays" there, you need to check UAEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName.
Best Regards
I am sorry but I don't follow you. I attach all my code:
Dim UserName As String = "user1"
Dim Password As String = "pass1"
If EasyUAClient Is Nothing Then InitUA()
Dim HandleID As Integer = 0
Dim item As OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments
Value = Nothing
If (String.IsNullOrEmpty(UserName)) Then
item = New OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments(OPCServer & OPCTag, OPCServer, OPCTag, New UAMonitoringParameters(Optional_OPCRequestedUpdateRate))
Else
endpoint.UserName = UserName
endpoint.Password = Password
item.EndpointDescriptor = endpoint
End If
HandleID = EasyUAClient.SubscribeMonitoredItem(item)
Return HandleID
They line in bold should be changed you mean?
Thank you in advance.
More:
You seem to be mixing two things, although the code seem to be incomplete. The WithUserNameIdentity extension method would be the right approach.
Setting UserName and Password directly on UAEndpointDescriptor is *not* the right approach, so trying to resolve why it behaves the way it behaves with the backslash is pointless. So you can just leave out these parts.
We use the following code:
Dim uAEndpointDescriptor As OpcLabs.EasyOpc.UA.UAEndpointDescriptor = UAEndpointDescriptorExtension.WithUserNameIdentity(New OpcLabs.EasyOpc.UA.UAEndpointDescriptor(OPCServer), UserName, Password)
uAEndpointDescriptor.set_UserName(UserName)
uAEndpointDescriptor.set_Password(Password)
LogTXT(String.Format("+++++++++ endpoint.UserName: {0} - endpoint.Password: {1} - endpoint.Port: {2}", uAEndpointDescriptor.get_UserName(), uAEndpointDescriptor.get_Password(), uAEndpointDescriptor.get_Port()), False, "")
IF We use the following user and password
USER: name\user
Password: 1234
We get the following data:
+++++++++ endpoint.UserName: - endpoint.Password: 1234 - endpoint.Port: -1
USER: nameanduser
Password: 1234
+++++++++ endpoint.UserName: nameanduser - endpoint.Password: 1234 - endpoint.Port: 65300
