Can't read item
If you need the subscriptions and they don't work, you need to look further in the DCOM configuration area. Make sure that DCOM allows access to the CLIENT by the SERVER (i.e. the reverse of the usual way), because that's what the async operations and subscription need for callbacks. Also, try a different settings for:
1.EasyDAClient.ClientParameters.UseCustomSecurity
2.EasyDAClient.ClientParameters.TurnOffActivationSecurity
3.EasyDAClient.ClientParameters.TurnOffCallSecurity
You can switch to sync-only by setting (on EasyDAClient object) the InstanceParameters.Mode.AllowAsynchronousMethod property to 'false'.
2. Console App
3. From what i know all readings are asynchronous, but i cant check source code, so im not 100% sure
4. just InstanceParameters.Timeouts.ReadItem, i was trying with diffrent timeouts, but same exception
Can you please answer this:
- Is the server local or remote?
- What kind of app are you developing? (Windows Forms, ASP.NET, Windows Service, ...)
- In the other apps, can you select between Synchronous and Asynchronous reads? Do Asynchronous read work?
- Are you setting any parameters on the EasyXXClient object?
ive started to use your dlls (eval at the moment) and im trying to read some data from Tac OPC server.
I can see all branches etc, but when i try to read any data from Item ive got an error:
"Read not completed. This error indicates that it could not be verified that the requested read operation was completed during the timeout period. It is possible that the read operation will actually succeed or fail, but later. Increase the timeout period if you want to obtain positive or negative indication of the operation outcome. Other reason for this error may be that under heavy loads, topic request or response queue is overflowing. Check the event log for queue overflow errors (if event logging is supported by the product and enabled)."
I can read from other apps, so there is no problems with OPC Server, i can also read Properties from Item, but cant read value(ReadItemValue or ReadItem). I was using your console example (C#).
Piotr
