Possible Session Timeout before SessionTimeout is hit
29 Jul 2021 13:31 #10066 by support
An updated, enhanced Knowledge Base article on OPC UA timeout settings: kb.opclabs.com/QuickOPC-UA_Timeout_Settings .
26 Jun 2018 13:50 #6479 by Holbach
Brilliant, thank you. That appears to have done the trick in 2018.1 as well.
Many Thanks!
26 Jun 2018 09:17 - 26 Jun 2018 09:17 #6472 by support
Thank you for reporting this.
This appears to be a bug on our side. We will fix it in version 2018.3; below is a workaround (tested with 2018.2).
Place the following XML snippet into the UA SDK configuration file, as sub-element of <SecurityConfiguration>:
<!-- The directory used to store invalid certficates for later review by the administrator. -->
    <RejectedCertificateStore>
      <StoreType>Directory</StoreType>
      <StorePath>%CommonApplicationData%\OPC Foundation\CertificateStores\RejectedCertificates</StorePath>
    </RejectedCertificateStore>
I hope this helps
Last edit: 26 Jun 2018 09:17 by support.
25 Jun 2018 21:51 #6470 by Holbach
The trace file shows the following:
Information(132): OPC-UA engine SDK configuration successfully provided by "OpcLabs.EasyOpc.UA.Toolkit.AppConfigSdkConfigurationProvider".
Error(1): INTERNAL ERROR. The OPC-UA engine might be in an unstable state.
An exception of type 'System.NullReferenceException' from source 'OpcLabs.EasyOpcUA' has occurred in OPC-UA guarded operation 'UAClientEngineBase.BeginExternalConnect'. The exception descend follows.
(1) {System.NullReferenceException} OpcLabs.EasyOpcUA(UpdateFrom) -> Object reference not set to an instance of an object.
25 Jun 2018 20:38 #6469 by Holbach
I've given the AppConfig UAConfigurationSources a shot but am seeing a different error with the ReadMultiple call now; specifically "Attempt to add existing item into a set." when the code hits:
ValueResult[] readResults = client.ReadMultipleValues(readNodes.ToArray());
I've switched to version 2018.1 to see if this might help but the behavior is the same.
I am using the config.xml file you linked to here www.opclabs.com/forum/ua-reading-writing-subscriptions/1781-...re-than-1-minute?start=10#3952 without any modifications. (just the name of the file)
The app.config file now contains:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
  <configSections>
     <section name="UAClientEngine" type="Opc.Ua.ApplicationConfigurationSection,Opc.Ua.Core" />
   </configSections>
  <UAClientEngine>
   <ConfigurationLocation xmlns="http://opcfoundation.org/UA/SDK/Configuration.xsd">
     <FilePath>yyyTestClient.config.xml</FilePath>
   </ConfigurationLocation>
  </UAClientEngine>
  <startup>
        <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5.2" />
  </startup>
</configuration>
15 Jun 2018 12:56 #6453 by support
15 Jun 2018 11:37 #6452 by Holbach
I am currently using version 5.23 and targeting Framework 3.5. I have a collection of about 2000 UAReadArguments that are being read in a single transaction - the read can take a LONG time to complete - 5+ hours - so I am looking for ways to increase the timeouts the EasyUAClient is using.
I've tried increasing all timeouts I was able to find, but am seeing the EasyUAClient send a Close Session request after exactly 10 minutes and 6 seconds (watching the traffic in a Wireshark), and I am catching a BadRequestTimeout - is there a timeout I am missing, and the session is being closed as a result (instead of being the cause of the timeout)
This is not the exact code being used, but is the same where it matters:
client = new EasyUAClient();
client.Isolated = true;
client.IsolatedAdaptableParameters.Session.CloseTimeout = 120000000;
client.IsolatedAdaptableParameters.Session.SessionTimeout = 120000000;
client.IsolatedAdaptableParameters.Session.SessionConnectTimeout = 120000000;
resultList.Add(client.ReadMultipleValues(readArray));
