Monitoring all variables in a DB
03 May 2018 15:26 #6298 by support
Of course you can do this with QuickOPC. There is no need to specify the monitored names explicitly.
// This example shows how to subscribe to changes of all data variables under a specified object in OPC UA address space.
using System;
using System.Linq;
using OpcLabs.EasyOpc.UA;
using OpcLabs.EasyOpc.UA.AddressSpace;
namespace UADocExamples._EasyUAClient
    partial class SubscribeMultipleMonitoredItems
        public static void AllInObject()
            UAEndpointDescriptor endpointDescriptor =
                "http://opcua.demo-this.com:51211/UA/SampleServer"; // or "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
            // Instantiate the client object and hook events
            client.DataChangeNotification += client_DataChangeNotification_AllInObject;
            // Obtain variables under "Scalar" node
            Console.WriteLine("Browsing...");
            UANodeElementCollection nodeElementCollection = client.BrowseDataVariables(endpointDescriptor,
                "nsu=http://test.org/UA/Data/;ns=2;i=10787");
            // Create array with monitored item arguments
            EasyUAMonitoredItemArguments[] monitoredItemArgumentsArray = nodeElementCollection
                .Select(element => new EasyUAMonitoredItemArguments(null, endpointDescriptor, element))
                .ToArray();
            Console.WriteLine("Subscribing...");
            client.SubscribeMultipleMonitoredItems(monitoredItemArgumentsArray);
            Console.WriteLine("Processing monitored item changed events for 20 seconds...");
            System.Threading.Thread.Sleep(20 * 1000);
            Console.WriteLine("Unsubscribing...");
            client.UnsubscribeAllMonitoredItems();
            Console.WriteLine("Waiting for 5 seconds...");
            System.Threading.Thread.Sleep(5 * 1000);
        static void client_DataChangeNotification_AllInObject(object sender, EasyUADataChangeNotificationEventArgs e)
            // Display value
            // Remark: Production code would check e.Exception before accessing e.AttributeData.
            Console.WriteLine("{0}: {1}", e.Arguments.NodeDescriptor, e.AttributeData.Value);
The following user(s) said Thank You: hcrowe
03 May 2018 13:18 - 03 May 2018 14:34 #6294 by hcrowe
Thanks for the response.
I was just curious because for my example I might have 1000 variables I want to monitor in a single DB. With your method I would have to enter 1000 lines of code one for each variable. The other would take maybe 6 lines of code to accomplish by browsing for the nodes then using the foreach loop to create each entry.
Also if the DB is modified I will have to modify my code to include the new variable. With a foreach if a new variable is added it will dynamically be included.
Anyways just curious if it was possible I really like your product.
Code Example:
public Subscription AddSubscription(string Startnodeid, string SubDisplayName, int PubInt, uint KeepAlive, uint LifeCount, uint MaxNotifyPerPublish, int SamplingInt, List<string> mylist)
            Subscription subscription = new Subscription(m_Session.DefaultSubscription)
                DisplayName = SubDisplayName,
                PublishingEnabled = true,
                PublishingInterval = PubInt, // in milliseconds.
                KeepAliveCount = KeepAlive,  // 10*UaRefreshRate  = 5s if UaRefreshRate = 500
                LifetimeCount = LifeCount,  // UaRefreshRate*100 = 50s if UaRefreshRate = 500;
                MaxNotificationsPerPublish = MaxNotifyPerPublish,
            foreach (var myrows in mylist)
                //OPCMonitoredNodeID = myrows[0].ToString();
                //Step 5 - Add a list of items you wish to monitor to the subscription.
                var BatchInputlist = new List<MonitoredItem>
                        new MonitoredItem(subscription.DefaultItem)
                            DisplayName = "Astec Monitoring",
                            StartNodeId = myrows,
                            AttributeId = Attributes.Value,
                            MonitoringMode = MonitoringMode.Reporting,
                            SamplingInterval = 250
                subscription.AddItems(BatchInputlist);
                m_Session.AddSubscription(subscription);
            //Step 6 - Add the subscription to the session.
            subscription.Create();
            //m_Session.Notification += new NotificationEventHandler(Session_Notification);
            //NodeId mynode = new NodeId(@"ns=3;s=""Inputs_FB_DB"".""Input1""");
            //DataValue dvread = session.ReadValue(mynode);
            //g_Notification = dvread.ToString();
            //MessageBox.Show(mynode.ToString());
            //MessageBox.Show(@"Input1 = " + dvread.ToString());
            return subscription;
Last edit: 03 May 2018 14:34 by support.
02 May 2018 15:12 #6285 by support
1. I do not quite understand this part: "How can I ... without creating a monitored item for each variable.". What's wrong with creating a monitored item for each variable? It is not even possible to subscribe to multiple variables without doing that; when you write " In the OPC Stack you can create a write list and create a subscription to all the variables", you are, in principle, referring to doing the same thing.
2. To your code: each element of UANodeElementCollection is a UANodeElement, and it has an implciti conversion to UANodeDescriptor. The line with call to the EasyUAMonitoredItemArguments constructor can therefore be written much easier, simply pass in the 'Nodes' variable as the 3rd argument).
02 May 2018 13:50 - 02 May 2018 15:07 #6284 by hcrowe
Hi I am currently evaluating your product. I am trying to figure out how to monitor all variables within a single Siemens DB. In the OPC Stack you can create a write list and create a subscription to all the variables. How can I accomplish this with Opclabs without creating a monitored item for each variable.
For Example:
UANodeElementCollection MyNodes = MyClient.BrowseDataNodes("opc.tcp://10.42.10.80:4840", @"ns=3;s=""OPCUA_PC_PLC"""); <---- loop through the Siemens DB and return all nodes then do a foreach and create my subscriptions.
            foreach (UANodeElement Nodes in MyNodes)
                //MessageBox.Show(@"ns=3;s=""OPCUA_PC_PLC"".""" + Nodes + "" + "   " + @"ns=3;s=""OPCUA_PC_PLC"".""EnableScale1""");
                MyClient.SubscribeMultipleMonitoredItems(new[]
                new EasyUAMonitoredItemArguments(null,"opc.tcp://10.42.10.80:4840", @"ns=3;s=""OPCUA_PC_PLC"".""" + Nodes + "")
Looking forward to your response.
Last edit: 02 May 2018 15:07 by support.
