Data Type changed by client?
12 Apr 2017 16:53 #5108 by support
Yes, this is done by QuickOPC, for interoperability with all kinds of .NET tools. Not all of them support UInt16 and other such types. See
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ata%20Types%20in%20OPC-UA.html .
- msdn.microsoft.com/library/12a7a7h3.aspx#Types
Declare your property as Int32 or wider, and you will be all set.
The following user(s) said Thank You: Captain_Dash
12 Apr 2017 15:30 #5107 by Captain_Dash
we run in an issue where we mapped a structure on the opc ua server to a similiar structure on the client site in c#. The data type on the server is UINT - 16 bit, 0 to 65535. At the c# side the Property which is mapped is an ushort - 16 bit 0 to 65535. The UpdateFailure event occurs and returns the following message:
Cannot set the target value to the object member 'UInt16 Statusword' of target type 'Orbotech.Spirit.HWComponents.PlcAxes.PlcMapping.AxisControl'. The inner exception contains details about the problem.
Inner Exception:
Object of type 'System.Int32' cannot be converted to type 'System.UInt16'.
We have no idea where the Int32 comes from. Is there something happening in the client?
I checked the type with a standalone client from another company and they say its Uint16.
Best Regards
André
