Activate NuGEt UA License
18 Oct 2018 11:25 #6759 by chrisachern
support wrote: I tried to determine which license you have, based on the domain of your email address on the forums.
I found that the latest license you purchased was on January 1, 2016, with 2 years maintenance, therefore covering all versions that we release until January 1, 2018. You should also be able to verify this by viewing the license details in the License Manager.
This means that (according to the data you can see on kb.opclabs.com/Versions ) you cannot use this license with version 5.53 - the release date is in June 4, 2018. The latest you can use is 2017.2 (5.51).
Thank you. This solved my Problem.
Best Regards,
Chris
18 Oct 2018 09:56 #6758 by support
Replied by support on topic Activate NuGEt UA License
The following user(s) said Thank You: chrisachern
18 Oct 2018 09:45 #6757 by chrisachern
i installed the Licence with the Licence Manager on my local machine. As you can see the EasyUAClient.LicenseInfo still Shows Trial.
Best Regards,
Chris
18 Oct 2018 08:52 #6755 by support
For version 5.53, the license needs to be installed under Component = "QuickOPC", not "QuickOPC 5.4".
Change that in the License Manager. If it does not give you the option (which may be the case if you only used NuGet and not the standalone installer), you have various options, such as:
a) use the standalone setup form 5.53 to install the License Manager together with the proper registry key Component= "QuickOPC".
b) create manually following - empty - registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Licensing\QuickOPC
c) use the command-line license manager (LMConsole) - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2....html#LMConsole%20Utility.html .
The part of the documentation to study in relation to this is: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ml#Application_Deployment.html
Have a look at the rightmost column in this table ("Licensing Component") if you need similar info later: kb.opclabs.com/Versions .
18 Oct 2018 07:46 #6754 by chrisachern
i have a machine where an OPC DA Client is installed an licensed (see pic). It uses the Version 5.40.251.1.
Now i want to install a second OPC UA Client on this machine. I used the nuget packages (Version 5.53.405.1).
The License should activate both Clients. But my UA Client says Run time is over the limit in license "Multipurpose".
How can i activate the UA Client?
Best Regards,
Chris
