Quality Codes in UA
07 Jul 2017 13:59 #5326 by support
Replied by support on topic Quality Codes in UA
Can you please describe what "loses connection to the tags" mean? Is that broken connection between the OPC Server and the target device, or (if not), what kind of lost connection are we talking about?
07 Jul 2017 13:40 #5325 by AdamBOD
Replied by AdamBOD on topic Quality Codes in UA
When it loses connection to the tags it just displays the last received data until it regains connection to the tags, what I want it to do is to display "Bad" under quality if it can't connect to the tags
07 Jul 2017 13:23 #5324 by support
I do not understand what you mean by "is not working". Describe what it does, in your case, and what you expect it to do.
07 Jul 2017 13:21 #5323 by AdamBOD
If attributeDataResult.Exception Is Nothing Then
row.Item("Quality") = attributeDataResult.AttributeData.StatusCode
Else
row.Item("Quality") = "Bad"
End If
This code doesn't appear to be working is there something that I'm missing?
07 Jul 2017 09:29 #5320 by AdamBOD
That was all I had, I was not aware of the Exception method. Would you be able to point me to some documentation for it?
07 Jul 2017 09:13 #5318 by support
I need more code around this. Do you test attributeData.Exception ?
07 Jul 2017 09:05 #5316 by AdamBOD
This is how I process them and it just stops on the last received data if connection is lost
07 Jul 2017 08:49 #5314 by support
As I wrote, that's not how it is supposed to work. If you are seeing different results and want us to look at it, you need to provide the details.
07 Jul 2017 08:42 #5313 by AdamBOD
I'm just wondering as to why the DA side of the API will return a bad quality code when it is unable to connect to the tags while the UA side just displays the last received data
Time to create page: 0.073 seconds
