Quality Codes in UA
30 Jul 2017 16:58 #5383 by support
Replied by support on topic Quality Codes in UA
I thought you were subscribing to the monitored items.
Are you instead invoking a Read periodically?
18 Jul 2017 15:28 #5371 by AdamBOD
Replied by AdamBOD on topic Quality Codes in UA
Sorry for the late reply, I query the tags every 2 seconds but it will vary from user to user
10 Jul 2017 15:57 #5340 by support
If it were under the debugger, then it would be, in principle, a behavior as expected. What happens is that in OPC UA, the "broken connection" is detected by in-band mechanism in the protocol itself. The client uses a so-called keep-alive count, and the server the so-called lifetime interval, to detect interruptions. These mechanism collide with using a debugger when the user sets breakpoints, and for this reason we try to negotiate a high keep-alive count and a long lifetime interval, when a debugger is detected. Consequently, interruptions are only detected after very long time (days), under the debugger.
Without a debugger, normally the time to detect an interruption should be much shorter, because that's what we, as client, "propose" (but in the client-server negotiation, the server has the final word).
I could not reproduce the issue here, and without having it reproduced I cannot help much further.
What kind of publishing interval are you using for monitoring the values? Something in milliseconds/seconds range, or something considerably longer? (the detection interval is derived from that).
10 Jul 2017 08:09 #5336 by AdamBOD
I've tried it both ways but the results are the same
07 Jul 2017 15:19 #5333 by support
Sorry, one more question: Are you testing while running under a debugger (e.g. from Visual Studio, the typical "F5" or green arrow toolbar button), or standalone (e.g. from command line, or launching from Windows Explorer)?
07 Jul 2017 14:49 #5332 by AdamBOD
It's generally opc.tcp
I'm not 100% sure of the configuration inside the PLC but the issue still occurs even when I'm using the demo opcua.demo-this.com tags
07 Jul 2017 14:45 - 07 Jul 2017 14:45 #5331 by support
Thank you. I have some more questions
1) is the protocol opc.tcp:, or http: ?
2) Do I understand it correctly that the PLCs your are connecting to have an embedded OPC UA server. That is, that there isn't a separate PC box in the middle with the OPC UA server that would in turn communicate with the PLCs?
Last edit: 07 Jul 2017 14:45 by support.
07 Jul 2017 14:13 #5329 by AdamBOD
It seems to be running Version 5.41.1186.1
07 Jul 2017 14:11 #5328 by support
I will try to reproduce this here. Which version and build are you using please? (best way to find out is from the Details tab when right-clicking on one of OpcLabs.* assemblies and doing Properties).
07 Jul 2017 14:04 #5327 by AdamBOD
Yes, I mean it loses actual connection to the tags, for example I have a demo PLC connected over ethernet and when I remove the connection the last received data is all that's displayed. I have simulated this as well with the demo OPC UA tags provided in the BrowseControl by just disconnecting from the network but it's the same story
Time to create page: 0.074 seconds
