Could not create a certificate via a proxy: Input file was not processed properly.
17 Mar 2016 09:59 #3935 by support
Dear Sir,
I could not find anywhere in your posts an indication that you are using our product (QuickOPC).
If you are using it, please clarify how and what do you think it does not work as expected.
If you are not using QuickOPC, then you need to look for help somewhere else (possibly with the vendor of the products you are dealing with).
17 Mar 2016 09:27 #3934 by david.weiss
i have installed "InstallOpcUaNetToolkit1.30.3".
If i try to start "Softing OPC UA Client" i got the following Information-Message:
Before you can use the softing OPC UA Client an application
instance certificate which will identify this installation must be
created.
A certificate with the following information will be generated:
	Application Uri: urn:NTB119:SoftingOPCUAClient
	Subject Name: Softing OPC UA Client
	Key Size: 1024 Bits
	Validity: 600 months
After clicking on "OK" i got the following Error-Message:
The Files "Opc.Ua.CertificateGenerator.exe", "Opc.Ua.DiscoveryServer.exe" and "REDIST.TXT" is located in the following directories:
"C:\Program Files\Common Files\OPC Foundation\UA\v1.0\Bin"
"C:\Program Files\Common Files\OPC Foundation\UA\v1.0\LDS\Bin"
"C:\Program Files\Common Files\OPC Foundation\UA\v1.1\Bin"
"C:\Program Files\Common Files\OPC Foundation\UA\v1.1\LDS\Bin"
"C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\Bin"
"C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.0\LDS\Bin"
"C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\Bin"
"C:\Program Files (x86)\Common Files\OPC Foundation\UA\v1.1\LDS\Bin"
If i try to start "Softing OPC UA .NET Demo Server" i got the Error-Message:
Load Application confoguration
EXCEPTION (FileNotFoundException)
Could not find file 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Softing\OpcUaNetDemoServer\Softing.Opc.Ua.DemoServer.Config.xml'.
STACK TRACE
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.IO.FileInfo.Open(FileMode mode, FileAccess access)
at Softing.Opc.Ua.Sdk.ApplicationConfiguration.Load(FileInfo file, ApplicationType applicationType, Type systemType, Boolean applyTraceSettings)
at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadAppConfig(Boolean silent, String filePath, ApplicationType applicationType, Type configurationType, Boolean applyTraceSettings)
After clicking on "close" i got the Error-Message:
UA Demo Server
EXCEPTION (ServiceResultException)
Could not load configuration file.
SERVICE RESULT (BadConfigurationError)
STACK TRACE
at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadApplicationConfiguration(Boolean silent)
at Softing.Opc.Ua.Sdk.Sample.Program.Main()
Can you help me with this 2 Problems?
17 Mar 2016 09:25 #3933 by david.weiss
created.
	Key Size: 1024 Bits
STACK TRACE
UA Demo Server
STACK TRACE
17 Mar 2016 09:12 #3932 by david.weiss
i have installed "InstallOpcUaNetToolkit1.30.3" and try to run "Softing OPC UA Client".
At the start i got the Information-Message:
"Before you can use the softing OPC UA Client an application
created.
	Key Size: 1024 Bits
	Validity: 600 months"
After click at "OK" i got the Error-Message:
"Could not create a certificate via a proxy: Input file was not processed properly."
The File "Opc.Ua.DiscoveryServer.exe", "Opc.Ua.CertificateGenerator.exe" and "REDIST.TXT" is located in the follow directories:
and
If i try to start "Softing OPC UA .NET Demo Server" the Error-Message:
"Load Application Configuration
at Softing.Opc.Ua.Sdk.Configuration.ApplicationInstance.LoadAppConfig(Boolean silent, String filePath, ApplicationType applicationType, Type configurationType, Boolean applyTraceSettings)"
after clicking on "close":
"EXCEPTION (ServiceResultException)
at Softing.Opc.Ua.Sdk.Sample.Program.Main()"
Can you help me, to fix this errors?
