Trying to read OPC UA value with Delphi
30 Aug 2017 14:40 #5464 by support
Does your code work with some other server? For example, our public demo server (the one used in examples?) It can easily be that the Node ID is correct, but the server is rejecting it for a reason that is outside of our control.
30 Aug 2017 13:49 #5463 by eh
I still get the same exception... BadNodeIdUnknown
Endpoint: 'opc.tcp://opc-pc:48010'
Node: 'nsu=http://IBHsoftec.com/IBHLinkUA/;ns=4;s=OPC_UA_2017.Lijn3.Generic.TW2_WCS_Ist'
29 Aug 2017 17:16 #5459 by support
Try to pass
DataDialog.NodeDescriptor.NodeId.ToString
as a 2nd argument to ReadValue instead.
The ToString method of the UANodeDecsriptor returns a string that is not in the right format.
I admit this is not very logical, as the 2nd argument is called 'nodeDescriptorString'. I will make a note and we will try to improve it in the future version.
29 Aug 2017 10:56 #5457 by eh
I'm trying to read a value from a tag on my OPC UA server.
Therefore I used following code, but I get an error(see attachment). What am I missing or doing wrong?
var Client: TEasyUAClient;
    Value: OleVariant;
    DataDialog: TUADataDialog;
    Endpoint, Node: string;
begin
  DataDialog := TUADataDialog.Create(nil);
  DataDialog.UserPickEndpoint := True;
  DataDialog.ShowDialog(nil);
  Endpoint := DataDialog.EndpointDescriptor.ToString;
  Node := DataDialog.NodeDescriptor.ToString;
  Client := TEasyUAClient.Create(nil);
  Value := Client.ReadValue(DataDialog.EndpointDescriptor.ToString, DataDialog.NodeDescriptor.ToString);
  cxtextedit3.Text := Value;
end;
