UA Client with VB6
18 Jan 2016 16:05 - 18 Jan 2016 16:05 #3785 by support
Replied by support on topic UA Client with VB6
I can confirm that QuickOPC 5.35.442.1 has a problem in the VB6 UADocExamples.
There are more issues, but one of them is that it is necessary to remove the parentheses around the arguments of WriteValue and similar calls (Sub-s that have no return value).
Last edit: 18 Jan 2016 16:05 by support.
18 Jan 2016 13:32 #3778 by support
UA Client with VB6 was created by support
I have a VB6 application I am trying your UA Client with. [...]. I have the read functions working, but each time I try the write function it fails with "Expected Function or Variable". I have the lines of code copied from your examples provided with the demo download and just changed the OPC reference. I don't know why this doesn't work?
The actual line of code is:
Dim Client as EasyUAClient
Client.writevalue("opc.tcp://WIN-895:55105","nsu=SYM:;s=S7-1200 station_1.PLC1.OPC_Data.Cylinder1 Pressure Setpoint",12)
The OPC reference works for the read functions OK
A.
