The CertificateGenerator utility is not installed. BadConfigurationError
26 Apr 2018 17:12 #6268 by support
The reason for this behavior is a bug in 3-rd party library we are using.
In version 2018.2, we will use a new version of it. In our testing, this appears to have resolved the issue.
Related thread: www.opclabs.com/forum/ua-general/2361-an-invalid-handle-was-...ified-after-app-25-sec?start=0
The following user(s) said Thank You: zaglerp
26 Apr 2018 12:07 #6266 by zaglerp
I am experiencing a strange behaviour on one single developer pc using version 2018-1.
Our really simple application terminates after a few seconds without throwing any exception:
   var x = new EasyUAClient();
   Console.ReadKey();
After enabling QuickOPC logging in the app.config I got:
LogEntry("OPCLabs-UAEngine",Error,0,102). The OPC-UA engine failed to connect to the underlying subsystems.
The CertificateGenerator utility is not installed. = BadConfigurationError. + The error occurred while checking the (client) application instance certificate. The certificate generator path was "". + This is an engine-level error..
When I put this line in the app.config
<add key="OpcLabs.EasyOpc.UA.Toolkit.UAClientEngineBase.EnableUACertificateGeneratorBoxer" value="false"/>
it works.
What is the reason for this behaviour?
Kind regards
Peter
