EasyUAClient.Install
09 Jul 2019 05:31 #7505 by admin
Replied by admin on topic EasyUAClient.Install
I was not able to precisely reproduce the issue, but I could get a situation in which the same certificate has been created twice in a row (the second overwriting the first one). By analyzing it, I found a timing issue which, in fact, can also explain your situation.
Please download the recent version, install it, rebuild your project with new assemblies, and re-test. It is available on NuGet and on our Web page. The version with the fix reports itself as 5.54.1281.1 or later.
02 Jul 2019 06:34 #7471 by support
Replied by support on topic EasyUAClient.Install
I will try to reproduce the issue, and will let you know here.
01 Jul 2019 07:07 #7465 by Runner
EasyUAClient.Install was created by Runner
Good morning,
we would like to use static method EasyUAClient.Install for certificate generation. We noticed, that one EasyUAClient.Install call generates two different certificate files in certificate store ("%CommonApplicationData%\OPC Foundation\CertificateStores\UA Applications"). Is there any reason why two files are created ?
Thank you for your help.
            EasyUAClient.SharedParameters.EngineParameters.ApplicationParameters.ApplicationName = "Test OPC UA Client";
            EasyUAClient.Install();
