error Run time is over the limit in license "Multipurpose"
14 Aug 2019 12:15 #7626 by support
1. Is this on the same computer as you were running before, or on a different (new) computer? Have something changed in between?
2. I suppose that you are aware that the license needs to be installed no only on the computer where you develop, but also on the target computer where tha pplication runs.
3. How have you installed the license on the computer that has the problem? Using the License Manager utility, or by some other means?
4. Can you please send a picture of the License Manager screen, with the license installed, via email to support09 (at) opclabs.com ? Thank you.
The newest QuickOPC is on www.opclabs.com/products/quickopc/downloads .
12 Aug 2019 06:38 #7615 by admin
I apologize for delay, it is vacation period. Will reply during the remainder of the week.
07 Aug 2019 09:50 #7609 by LuisGar
It seems that I have a License Problem, when I open the configuration tool I get this. the values are not updated exactly 30 min after I start the application.
Run time is over the limit in license "Multipurpose". The license you have (most likely trial version) does not provide valid data after certain time period expires. Note that after the component's process is simply restarted, valid data will be provided again. Obtain and install proper license to permanently resolve this error.
07 Aug 2019 09:31 #7608 by LuisGar
it seems that someone had a similar Problem, www.opclabs.com/forum/ua-reading-writing-subscriptions/2669-...-stopped-firing-events?start=0
OPCLabs.BaseLib.dll 5.54.1281.1
OPCLabs.EasyOpcClassic.dll 5.54.1281.1
in that post you comment about building with Version 5.54.1296.1, but I dont know where I can find it,
07 Aug 2019 06:11 #7607 by LuisGar
Well, now I have another Problem, if I ignore the time the program now requires to load and continue running it, after a while, the OPC Connection stops working, I dont get any update of the data, I means not new Events are fired by the OPCClient, The same variables are being monitored by another tool which also use OPC protocol, so the OPC Server is still working. In my error log files I found no error at all related with OPC.
