EasyDAClient prevents WinForms application from closing immediately
19 Mar 2018 08:01 #6157 by support
Unfortunately not.
It's when the whole application (process) is shutting down.
17 Mar 2018 18:45 - 17 Mar 2018 18:52 #6155 by gojanpaolo
Is there any way to force this `cleanup` and know when it is done cleaning up? Thank you for your help.
Last edit: 17 Mar 2018 18:52 by gojanpaolo.
17 Mar 2018 14:21 #6153 by support
I am afraid we won't be able to help here.
There is some internal cleanup work that the component does, and we consider this delay as normal.
I am sorry I cannot give you better news...
16 Mar 2018 18:41 #6152 by gojanpaolo
About 3 seconds.
Jan
16 Mar 2018 17:00 #6151 by support
how long is the delay?
16 Mar 2018 16:27 - 17 Mar 2018 14:03 #6150 by gojanpaolo
We use EasyDAClient in a WinForms application. When we use EasyDAClient.SubscribeItem or EasyDAClient.SubscribeMultipleItems, it takes a long time for the application to close immediately (during Visual Studio Debug session).
We tried explicitly calling Dispose, UnsubsribeAllItems, and/or UnsubscribeItem but still doesn't fix the issue.
Here is a sample of our code...
public partial class frmDemo : Form
        private EasyDAClient _easyDAClient = new EasyDAClient();
        private float MyValue;
        public frmDemo()
            InitializeComponent();
            _easyDAClient.SubscribeItem("", "My.Server.Name", "My.Tag", 50, (s, e) => MyValue = (float)e.Vtq.Value);
        private void frmDemo_Load(object sender, EventArgs e)
            timer1.Enabled = true;
        private void timer1_Tick(object sender, EventArgs e)
            textBox1.Text = MyValue.ToString();
Additional information:
OpcLabs.QuickOpc 5.52.91 (from Nuget)
.NET Framework 4.6.1
Microsoft Visual Studio Enterprise 2017 Version 15.6.1
Thank you,
Jan
Last edit: 17 Mar 2018 14:03 by support.
