VB6 + QuickOPC-2018.2 Run-time error
24 Sep 2018 12:41 #6711 by support
I am glad it works. But in fact, this is just a workaround. It should work without it as well. We will have a look at it, and hopefully improve in version 2018.3.
24 Sep 2018 12:26 #6710 by Vladimir
Re-run the Steup, choose a custom installation, select "full" install type, and, just to be absolutely sure, verify that "Embedded assemblies" is checked in the list of installation components.
I do it and now it is OK! Thank you very mutch!
24 Sep 2018 12:02 #6709 by support
Can you please try to:
1. Install this on the computer: www.microsoft.com/en-us/download/details.aspx?id=53840 .
2. Re-run the Steup, choose a custom installation, select "full" install type, and, just to be absolutely sure, verify that "Embedded assemblies" is checked in the list of installation components.
BTW, have you tried the same on some other computer?
The following user(s) said Thank You: Vladimir
24 Sep 2018 11:14 #6708 by Vladimir
Good day! I installed QuickOPC-2018.2. When I run the project from the VB6 sample library, I get this error: "Run-time error -2147024894 (80070002)." Automation error. The system can not find the file specified. "
If I install QuickOPC-2018.1 and put earlier time, then such an error is not observed.
How i can use QuickOPC-2018.2 and VB6?
