while doing a tryout, a run time is over error occures
21 Nov 2013 14:22 #1557 by support
It does not matter whether the component is used from within your application, or in a design mode from Visual Studio. It counts the runtime since it was first used.
Whenever this happens, exit the Visual Studio and start it again. That should allow you continue normally again for at least 30 minutes.
21 Nov 2013 14:16 #1556 by bietho
Hi.
Today I downloaded the trail version from the QUICK OPC UA.
While I want to do the first steps, the following Message occured. I was trying to connect the textbox to a OPC UA Server!
Run time is over the limit. The license you have (most likely trial version) does not provide valid data after certain time period expires. Note that after the component's process is simply restarted, valid data will be provided again. Obtain and install proper license to resolve this error.
So the application wasn't runnig, how could this message pop up?
Thanks for your help in advance.
Kind Regards
Time to create page: 0.047 seconds
