License error
04 Apr 2013 13:21 #1278 by LiteByte
Replied by LiteByte on topic License error
Thanks but I need the 32 bit version of license manager... where do I get this?
04 Apr 2013 13:20 #1277 by support
Replied by support on topic License error
I would also like to add one thing that may not be immediately obvious: If you are installing a license that was issued for version 5.20, then if you are using it with version 5.20, in the License Manager, the "Component" selection should be "QuickOPC.NET 5.2".
You can use the same license for version 5.21, but because in this version, the earlier product editions (.NET, -COM, -UA) are merged together, you need to install this license under Component = "QuickOPC 5.2" (this comes up automatically as one of the options when version 5.21 is installed using its setup program).
I hope this helps.
04 Apr 2013 12:44 #1276 by support
Have you followed all instructions in the "Concepts" document (available from Start menu after QuickOPC is installed), Section 8. Application Deployment?
04 Apr 2013 11:58 #1275 by LiteByte
License error was created by LiteByte
Hi all,
I've the following problem: I designed a program for communication with opc and sap. When I deploy the program on another machine (not the dev machine) the opc client stops working after a few minutes. Please tell me how to license programs outside my development environment.
EasyOPC.NET Version: 5.21.132.1
Kind Regards
