Filter on Category
26 May 2014 06:38 #1994 by support
Replied by support on topic Filter on Category
This bug is fixed in QuickOPC 5.23.1211.1, which is now in the public download area (no action needed on your side, C., as you have been provided with this build last week already).
20 May 2014 12:31 #1984 by cdunlap
Replied by cdunlap on topic Filter on Category
Thanks for looking into this. If you need any further information from me, please just let me know.
19 May 2014 14:37 #1980 by support
Status: Currently reproduced on my side.
18 May 2014 13:28 #1975 by support
C., from what you have described, it sounds like a bug. I will try to reproduce and will let you know more then.
16 May 2014 21:05 #1971 by cdunlap
Filter on Category was created by cdunlap
I am trying to filter on category IDs. I have successfully filtered based on Areas/Source, but for some reason, I cannot get the Category filter to work.
Example code looks something like this:
Dim EasyAEClient As New OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient
Dim myState As OpcLabs.EasyOpc.AlarmsAndEvents.AEConditionState
Dim myFilter As OpcLabs.EasyOpc.AlarmsAndEvents.AESubscriptionFilter
Dim myAttributesForSelectedCategories As OpcLabs.EasyOpc.AlarmsAndEvents.AEAttributeSetDictionary
Dim myFilterCategories() As Long = Nothing
Dim MyHandle As Integer
myState = New OpcLabs.EasyOpc.AlarmsAndEvents.AEConditionState
myFilter = EasyAEClient.CreateSubscriptionFilter
myAttributesForSelectedCategories = New OpcLabs.EasyOpc.AlarmsAndEvents.AEAttributeSetDictionary
myAttributesForSelectedCategories = ... doing some stuff to fill that variable
myFilterCategories = {1, 2, 3}
myFilter.Categories = myFilterCategories
''myFilter.Sources = {"computer.clock.timer"} ... works fine if I use this instead of setting myFilter.Categories
AddHandler EasyAEClient.Notification, AddressOf EasyAEClient_Notification
MyHandle = EasyAEClient.SubscribeEvents(“physicalServerName”, “OPCAEServerName”, 1000, myState, myFilter, myAttributesForSelectedCategories)
Private Sub EasyAEClient_Notification(ByVal sender As Object, ByVal e As OpcLabs.EasyOpc.AlarmsAndEvents.EasyAENotificationEventArgs)
''This is where e.Exception has the value “{[12585986] *** System.ArgumentException: The parameter is incorrect. }“
End Sub
I have also tried using QueryEventCategories to get the available categories and add them all to a long array in order to pass them in to the filter. If I do this, the EasyAENotificationEventArgs.Exception property contains “{[12585986] *** System.ArgumentException: The parameter is incorrect. }“ whenever I get a notification of an event as well. I do not run into this issue with Areas or Sources. Is there something I am missing? How can the filter effect the events notification in such a way that it has invalid parameters?
Using version 5.2 with VB.NET and have tried with several different servers ( Softing, Matrikon, the OPCLabs.KitEventServer)
Any ideas on what I am missing?
