Problem with live mapping
  • miron
04 Mar 2015 17:13 - 04 Mar 2015 17:14 #2904 by miron
Replied by miron on topic Problem with live mapping
Currently I am using: KepSerwer V5.16.728.0
I attached two files:
1. Is KepSerwer project. You you could ope and load this project (I changed extension to txt)
2. csv file with list of tags.
In this case you need create memory channel: "common2OpcModel"
and driver: "msarna"
and import tags.
Last edit: 04 Mar 2015 17:14 by miron.
04 Mar 2015 16:57 #2903 by support
Replied by support on topic Problem with live mapping
Can you provide the server configuration so that I can actually try to reproduce it?
  • miron
04 Mar 2015 15:41 - 04 Mar 2015 15:54 #2902 by miron
No, unfortunately it did not help.
I have attached linqpad file with test.
In OPC this tag is defined as dword.
Last edit: 04 Mar 2015 15:54 by miron.
04 Mar 2015 15:31 #2901 by support
Please try changing the type of the Value property from 'uint' to Int64, so that it becomes CLS-compliant (msdn.microsoft.com/en-us/library/12a7a7h3.aspx ).
  • miron
04 Mar 2015 15:11 - 04 Mar 2015 15:12 #2900 by miron
And I added pice of code:
   td.LoadZonePosition.RwTestData.Value = 9001;
   mp.WriteTarget(td.LoadZonePosition.RwTestData,true);
   Thread.Sleep(1000);
   td.LoadZonePosition.RwTestData.Value = 0;
   mp.ReadTarget(td.LoadZonePosition.RwTestData,true);
Writing is working but Reading by using mapping is not working.
Could you help me?
Last edit: 04 Mar 2015 15:12 by miron.
  • miron
04 Mar 2015 11:54 - 04 Mar 2015 13:19 #2899 by miron
Problem with live mapping was created by miron
Hi, I have problem with live mapping.
It looks that read write is working and
also subscribing by EasyDAClient but live mapping is not working.
I have provided example and logs.
I have tested for two KepSerwer drivers:
1. Memory Driver (it works normal - without problems with crating own copy of data for each group with update rating)
2. TCP Simens (with connection with PLC)
log
In log you could see: "[Mapped thread] LoadZonePositio : 0 " value is not replicated
but normal subscription is working:
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 2 {System.Int64} @2015-03-04 11:36:39; Good
And it looks that mapping was done:
1: [Mapped thread] NodeDescriptor.BrowsePath=/common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition
(from NodeDescriptor)
2: [Mapped thread] Exception=null
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 0
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 24 {System.Int64} @2015-03-04 11:36:33; Good GoodNonspecific LimitOk (192)
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 0 {System.Int64} @2015-03-04 11:36:34; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=0 {System.Int64} @2015-03-04 11:36:35; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 1
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 1 {System.Int64} @2015-03-04 11:36:36; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=1 {System.Int64} @2015-03-04 11:36:37; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 2
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 2 {System.Int64} @2015-03-04 11:36:39; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=2 {System.Int64} @2015-03-04 11:36:39; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 3
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 3 {System.Int64} @2015-03-04 11:36:41; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=3 {System.Int64} @2015-03-04 11:36:41; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 4
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 4 {System.Int64} @2015-03-04 11:36:43; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=4 {System.Int64} @2015-03-04 11:36:44; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 5
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 5 {System.Int64} @2015-03-04 11:36:45; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=5 {System.Int64} @2015-03-04 11:36:46; Good GoodNonspecific LimitOk (192)
code
void Main()
   var root = "/common2OpcModel";
  TestData td = new TestData();
   var mp = new DAClientMapper();
   var d = new DAMappingContext()
			ServerDescriptor = Test.cServer,   // local OPC server
			NodeDescriptor = new DANodeDescriptor { BrowsePath =  root + "/msarna/L1/Z1/ZonesCtx"},
			GroupParameters = 300,
   mp.Map(td, d);
   mp.Client.SubscribeItem(Test.cServer,
         new DAItemDescriptor() { BrowsePath= root + "/msarna/L1/Z1/ZonesCtx/LoadZonePosition"},
		 300,(e1,e2)=>
      Console.WriteLine("[Subscribed event] LoadZonePositio : " + e1.ToString() + e2.ToString());
   },null);
   mp.Subscribe(true);
   uint val = 0;
   var t1 = new Thread(()=>{
	     while(true)
           Test.TestReadWrite(root +"/msarna/L1/Z1/ZonesCtx", "LoadZonePosition", val, true);
		   // or writing by rw mapping
		   //td.LoadZonePosition.RwTestData.Value = val;
		   //mp.WriteTarget(td.LoadZonePosition.RwTestData,false);
		   Thread.Sleep(1500);
		   val++;
		   if(val >40)
		       val =0;
   var t2 = new Thread(()=>
	   Thread.Sleep(1000);
	   Console.WriteLine("[Mapped thread] NodeDescriptor.BrowsePath=" + td.LoadZonePosition.CvTestData.NodeDescriptor.BrowsePath.ToString() );
	   Console.WriteLine("*************************************************");
		while(true)
			Console.WriteLine("[Mapped thread] LoadZonePositio : " +  td.LoadZonePosition.CvTestData.Value );
			if (td.LoadZonePosition.CvTestData.Exception != null)
				Console.WriteLine("[Mapped thread] Exception=" + td.LoadZonePosition.CvTestData.Exception.Message);
			else
			    Console.WriteLine("[Mapped thread] Exception=null");
			Thread.Sleep(1500);
	t1.Start();
	t2.Start();
	t1.Join();
	t2.Join();
[DAType]
public class TestData
     public TestData()
	    LoadZonePosition = new CvRwBoxTestData();
	 [DANode()]
     public CvRwBoxTestData LoadZonePosition  {get;set;}
[DAType]
public class CvRwBoxTestData
   public CvRwBoxTestData()
       //I have commented RW value mapping
	   //RwTestData = new RwTestData();
	   CvTestData = new CvTestData();
  // [DANode(BrowsePath = "")]
  // public RwTestData RwTestData {get;set;}
   public CvTestData CvTestData {get;set;}
[DAType]
public class RwTestData
   [DAItem(Operations = DAItemMappingOperations.Subscribe)]
   [DARead(DataSource = DADataSource.Device)]
   public uint Value {get;set;}
   [DAItem(Kind = DAItemMappingKind.Exception,
           Operations=DAItemMappingOperations.ReadAndSubscribe)]
   public Exception Exception {get;set;}
   [MetaMember("NodeDescriptor")]
   public NodeDescriptor NodeDescriptor { get; set; }
[DAType]
public class CvTestData
   [DAItem(Operations = DAItemMappingOperations.ReadAndWrite)]
   [DAItem(Kind = DAItemMappingKind.Exception, Operations=DAItemMappingOperations.ReadAndWrite)]
class Test
   public const string cServer = "Kepware.KEPServerEX.V5";
   public static void TestReadWrite(string rootPath, string valName, object value, bool isolated)
     string path = rootPath + "/" + valName;
	 Console.WriteLine("[TestReadWrite] Test for: " + path + ", isolated: " + isolated.ToString() + ", value: " + value.ToString());
	 EasyDAClient c1 = new EasyDAClient();
	 EasyDAClient c2 = new EasyDAClient();
	 c1.Isolated = isolated;
	 c2.Isolated = isolated;
    c1.WriteItemValue(new ServerDescriptor (){ ServerClass = cServer},
	  	              new DAItemDescriptor() { BrowsePath= path},value);
	Thread.Sleep(1000);
	var ds = new DAItemDescriptor() { BrowsePath= path};
	if (value is bool)
		ds.RequestedDataType = VarType.Bool;
	var valB = c2.ReadItem(
		ds ,
		new DAReadParameters(){ DataSource= DADataSource.Device, }
	Console.WriteLine("[TestReadWrite] ValueAfterRead=" + valB.ToString());
Last edit: 04 Mar 2015 13:19 by miron.
