Is there any way to retrive ItemId (full BrowsePath) for DAItem?
16 Feb 2015 06:43 #2777 by support
There are two obstacles here, but both can be resolved.
First, you cannot directly obtain the ItemId. As you have already figured out, you can obtain the NodeDescriptor. But, ItemId is contained in the NodeDescriptor. That should be enough (is there any reason why you specifically need ItemId as a separate member?). You can therefore use you first example, and access it as <ExampleClassInstance>.NodeDescriptor.ItemId from the code.
Second, the MetaMember mapping provides information that elates to the node being mapped, and not to any specific node (inside it) you specify. For example, if an instances of ExampleClass is mapped to a node "Channel1.Device1", then if you are interested in an item "Channel1.Device1.Tag1", you cannot do it right on the ExampleClass with [MetaMember("NodeDescriptor")]: You need to set up an object mapping for Tag1, and THEN use [MetaMember("NodeDescriptor")] on that object.
Just out of curiousity, can you please describe you scenario, i.e. why you specifically need this, and what are you trying to achieve?
  • miron
15 Feb 2015 22:39 - 15 Feb 2015 22:41 #2774 by miron
Maybe like this:
    [DANode(BrowsePath = "SomeValue")]
    [DAItem(Kind = DAItemMappingKind.ItemId)]
    public string SomeValueItemId
        get
        set
But (if I good remember) there is no "ItemId" value in enumeration type.
Last edit: 15 Feb 2015 22:41 by miron.
  • miron
15 Feb 2015 22:35 - 15 Feb 2015 22:37 #2773 by miron
QuickOPC.NET provides attribute: MetaMember.
This attribute allow to retrive some information by mapping.
Below example of idea:
   public class ExampleClass
    public DANodeDescriptor NodeDescriptor { get; set; }
   [DANode()]
   [DAItem()]
   public int  SomeValue {get;set;}
   [Some attribute]
   public string  SomeValueItemId {get;set;}
   //In this place I would like to get ItemId of mapping SomeVale
Next 'SomeValueItemId' I could use e.g. in EasyOPC.NET.
Last edit: 15 Feb 2015 22:37 by miron.
Time to create page: 0.074 seconds
